problems with exaust amnifold gasket
am eperiencing issues with the exhaust manifold gasket leaking
have used the one piece gasket from the Payen set which just burns away and the "two piece" stainless one from the EFI , which loses the center material and then leaks - any suggestions?
they both are a metal type one piece gasket that can go on either mfi/efi it's down to port shape which gasket you use out of the gasket sets sounds like your getting wrong gaskets sent to you
What you need is a genuine ford gasket mate, the payen ones and other aftermarket ones DON'T have the metal sealing rings where the ports are like the ford ones do. I had the same problems mate, and it will solve it.
as said mate get the genuine ford one, its got fire rings so it wont blow, payen make all the gaskets inc head for Ford but insist putting a shit manifold to head in the pack!
DavidK
27-09-2015 02:55 PM
Russ Payne
25-09-2015 08:29 PM
