heater prob
heater prob
the problem is when the engine is warm the heater is only luke warm, all pipes under the bonnet are hot, the heater box is hot down the right hand side, but the heater is only blowing warm on the first speed, if i click it onto speed 2 or 3 it blows cold,
cheers, neil
cheers, neil
The hose will be fine just remove both hoses from the bulkhead and wash it through both ways. you may get a load of brown water come out if its bad. just dont have the hose tap on to hard, gently does it ok!
fushed it through tonight and water was clean, still have the same prob so will change the stat at the weekend, is it best to buy a gen one or will a pattern part be ok?
the gauge sits on m of 'norm' (the fan kicks in between m and r) and when i drive it drops down between the solid white block at the bottom and m. defo got a stat in there, saw it when i did hg last december. you can see the water swirling around in the header tank when its warm????????
check that the feed and return hoses are hot and if thats the case try the lever that changes the temp from hot to cold on the heater box is not stuck/playing up!
stuck a thermostat in on saturday and its a bit better but look's like i will need to change the matrix
mk1focus
Ford Fiesta
24-09-2015 06:19 PM
