2.1 ZVH How is it done.........
Id like to know the cost aswell need see my tuner,as i understand its cvh head mated to a 2.0i zetec block,suppose to give lots of torque.Notsure what pistons to use have been told that people use calibra turbo pistons.
Wye Valley Hardcore
You need the C20XE N/A pistons for a ZVH build, NOT the C20LET pistons. They are for a Zetec Turbo conversion.
These pistons and rods would make a very solid ZVH ![Smokin](https://passionford.com/forum/images/smilies/icon_smokin.gif)
http://www.cnc-motorsports.com/produ...ID=21725&CtgID=
Bodger of Blackburn
good price as long as customs don't sting you.
That compression ratio of 9:1 is for a Zetec engine, the Zetec cylinder head has a smaller combustion chamber than the CVH head, meaning that if you fit those to a ZVH the compression ratio will be lower, somewhere around 8:1
Wye Valley Hardcore
Providing you use them as a pair from the correct engine, eg silver top rods and silver top pistons or black top rods and black top pistons they fit perfectly in either engine.
That compression ratio of 9:1 is for a Zetec engine, the Zetec cylinder head has a smaller combustion chamber than the CVH head, meaning that if you fit those to a ZVH the compression ratio will be lower, somewhere around 8:1![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
![Pthbbbb](https://passionford.com/forum/images/smilies/smile045.gif)
![Rolling Eyes](https://passionford.com/forum/images/smilies/icon_rolleyes.gif)
Balls Deep!
Stage 3 Big Valve Head Including Newmans Cam/lifters, around Ł1000 from say NMS.
Stage 3 T3 around Ł800 from TT or CR Turbos.
EFI Management Ł500-Ł1500 depending what you go for (MS, Cossie, Gotech, etc..)
You can of course try and source all that second hand which will save a fair bit.
IMO if you do not have all those box's ticked you may as well just build a good CVH, because without all of those you'll struggle to make more than 200bhp
I have put together this guide to the assembly.
http://www.sitechracing.co.uk/ford-z...uild-guide.asp
Bodger of Blackburn
if you want to build a cheap one to hit around 220bhp+, then 1.8 bottom end, earlier the better and skim the pistons, ported head big valves if you want, cossie turbo, 2wd or better a 4wd, you'll see a fair amount of acceleration pal.
to do it right for big power, then steel rods and forged pistons, big valve head (but you may as well go 16v for the extra cost)
powered by K26
Bodger of Blackburn
about Ł300 i reckon for the bottom end, new pump and tensioner, head bolts, skimming pistons etc.
it's cheap for sure, you still need a ported head and a decent turbo, then there's the management side of things, i'm on megasquirt with 440cc injectors, so that's a fair chunk of cash on top, mfi just doesn't cut it for efficiency and reliability IMO.
plan on a grand and a half to get it done cheap, sourcing used parts. and sell all the bits you have already if you can.
Oh ok that sounds fair enough....
Its running ofab Efi will that be fine
Balls Deep!
It's expensive and very few tuners have the required equipment to map it, OFAB and OFAC are only really any use if you run a CVH and are happy with an of the shelf chip, I dont know if there is one available for a ZVH? Probably not as there are so many variations!
Standalone management or MFI running 200bhp'ish are your options, but as I said above if your only going 200bhp stay CVH and save a bag load of cash!
You could go 5th injector but that still leaves the unreliable MFI setup in play.
Bodger of Blackburn
megasquirt it then, few quid for sure, but you can then fit it to most engines, so an investment in the long run.
since you're already on efi, there isn't much to be changed, you'll need to cut out the multiplug going to the current ecu and then solder in wires from ecu to bits of loom you need.
Balls Deep!
Trouble with MS is that again not many tuners will map it because of the potential problems caused by the DIY installer ![Sad](https://passionford.com/forum/images/smilies/icon_sad.gif)
If there is one local to you then go for it, because as wishy says it's just as case of wiring it in which is really easy of your already EFI![](https://passionford.com/forum/images/smilies/smile012.gif)
If not then ask your tuner what management he prefers and go for that, as he'll be mapping it
If not then ask your tuner what management he prefers and go for that, as he'll be mapping it![Wink](https://passionford.com/forum/images/smilies/icon_wink.gif)
