2.0 Silvertop - 6 speed ST170 box
Which clutch? Apart from the mounting of the box what modifications are needed?
Any help/leads much appreciated...
Edit: It going in a mk3.
YES I KNOW I CANT SPELL
drive shafts rear mount rember its an electrick speedo not cable. its also cable change gearbox so you will need all of that set up out of the focous ect ect
as for clutch you can use the st170 flywheel and clutch depending on power if not or as a few of my mates have done you will need an after market clutch setup
