ZT inlet and cam cover.
Got myself a blacktop with a 2.0 mondeo inlet. Bought a complete engine gasket set and it's got 3 lots of inlet gaskets. A metal one, a paper one and the little spade shape rubbers that fit around the ports. Questions is, which ones do I use?
Also, on a mk4 escort, does the cam cover fit or will it foul on the inner wing?
So that has brand new rubber inserts. I just wouldn't have thought it would bolt straight onto the head using just those.
Thanks for clearing it up chaps.
The plastic upper part needs a notch cutting out to clear the inner wing/mount area. The alloy part needed quite a bit cutting off to allow it to fit in, you can only get the one bolt in to hold it in place once the engine is fitted, so I bonded it at the back end.
I can try and grab you a couple of pictures if you want, later in the week?
If you wouldnt mind putting a few pics up and i'll see how much is involved.
Chopshop85 (12-09-2015)
07-10-2015 12:56 PM
