Electrics just gets worse
Just gets worse lights know work as the last how ever many owners have choped into so much of the wireing for stereos alams and what ever else no earth behind the dash so dash has been out re earthed it all then had the light carriers cleaned and new earthing, and know i have lights all doing what they should be BUT now had call from garage the gear box oil seals are so bad the car is dropping oil all over there floor so new oil seals then oil and filter change then they called to say the cam belt is split and some rubber teeth are slitting from the belt . new cam belt , then they call to say the peddal box is totalled ,to be fair i did wonder why i had to keep kicking the clutch pedal back into place all the bushes and links have come apart .new pedal box,cost so far £350 notes £50 notes to jano to set it up as it was running 25psi of boost when he got it i done 40 miles in it so far cost me 400 notes is this the most expensive car £ per mile ???? lets hope this is it for now
