PDA
View Full Version : Ford Escort RS Turbo
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 [60] 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107
  1. zvh headgasket
  2. fwd gripper diffs, where from?
  3. steering rack
  4. braided fuel lines
  5. Fiesta turbo inlet manifold any restrictions ?
  6. fifth injector kit
  7. TALL BLOCK PISTON PROBLEM
  8. where can i get a new/recon metering unit?
  9. will these fit on a series 2
  10. mk6 rs 2000 seats fit in my s2 ?
  11. turbo and 2/3i crank
  12. putting a s2 turbo on a s1 engine
  13. Cold start
  14. Ford? New shell
  15. who will fit
  16. bump steer
  17. cheapest place to buy a newman cam from cheers
  18. replacing s1 driver seat foam
  19. Newman Cam ???
  20. pro alloy radiator are these any good?? on my s2
  21. Series 1 Intercooler upgrades
  22. RS Turbo hid light conversion ?
  23. 2 quick Q's ASAP
  24. Turbo pic
  25. xr3i efi turbo conversion
  26. help with pistons
  27. piper timing belts
  28. TCA's
  29. series 1 antirollbar on a series 2??
  30. How to bleed coolant system
  31. erst gearbox oil?
  32. cross member
  33. rs turbo bumper splitter
  34. cosworth racing pistons.
  35. Mongoose or Magnex 2.5 bore exhaust??
  36. where can i get.....
  37. cossie T3 onto RST?
  38. turbo metal water pipes
  39. brake pedal travel
  40. Need upper cam pulley $$$$$
  41. Mk3 Escort RWD
  42. FAO Christian APT
  43. fans indicators and heaters dont work
  44. Help How To Remove Abs On S2!!!
  45. anti roll bar???????
  46. water preassurising why
  47. is this chipped
  48. Hi - Few Questions....
  49. rs turbo chatter
  50. re spray?
  51. OIL PREASSURE
  52. airtec s/s manifold 300sheets
  53. will rs 1600 suspension fit s2
  54. header tanks
  55. rs turbo wont start whilst its hot
  56. Radiator
  57. anybody.....
  58. Airtec alloy radiators
  59. Omex rev limiter for EFi CVH
  60. FOCUS RS ENGINE IN S2
  61. why use surpresor on ofab conversion
  62. Recirculating Dump Valve?
  63. triple gauge heater unit for 52mm gauges
  64. pressure in header tank
  65. looking for 90 spec bumpers in white. swap for cossy bumpers
  66. chipping advice
  67. rear drum brakes on a series 2
  68. how much is a recon for a turbo
  69. cvh engine build
  70. New Series One/ RS1600i/ mk3 Escort WEBSITE
  71. charge cooler
  72. cossy wiring on my s2 help
  73. Emissions Help please
  74. help alarms a cnut
  75. Zetec Turbo Pictures.....
  76. radiator
  77. early/late series 2 boxes
  78. Upper and lower Pulleys and electrical question. Help pls
  79. had enough of s1 need advice
  80. really dont know wether my exhaust is standard?
  81. passionford meet?
  82. Limits of the 1600CVH
  83. routing boost pipes with area six manifolds help
  84. now christmas is over(now with photo of baby jack)
  85. what paint should i paint me gearbox in??
  86. another dead turbo
  87. Turbo Actuator not setup i think
  88. starter motor erst
  89. engine bays
  90. std cam
  91. Series 1 Indicator
  92. escort s2 exhaust
  93. Turbo advice Pic added
  94. B&M shifter or Racing Puma Shifter?
  95. RST into an escort mk6
  96. RS 2000 handbrake cable for conversion
  97. S1-S2 Fuel Pump Brackets
  98. eibach for sale
  99. car wont start just rebuilt
  100. LIGHTS ON WHEN BRAKING?????
  101. removin 4spoke rs s/wheel??
  102. Suspension advice
  103. bonnet catch
  104. need inner flitch for a mark 3 cabs
  105. WHATS THE SMALLEST WHEELS I CAN FIT WITH 324mm BRAKES??
  106. Recaro Spares??
  107. T3 Turbo Needed :(
  108. recaro leather
  109. efi conversion
  110. will these recaros bolt straight in my escort mk4...
  111. handbrake cable mk3/mk4
  112. afr gauge on series2
  113. gearbox removel/reffitting
  114. Advice on EFI Conversion
  115. is this chip eny gud
  116. rwd s2.............
  117. Oil coming from DV
  118. escos rims on an rs turbo, any pics..??
  119. Strut brace to fit EFi conversion
  120. WANTED
  121. rs turbo wont start when warm
  122. What affect water temp
  123. apex springs
  124. anyone fit me a engine... northeast england
  125. misfiring rst.
  126. Need more fuel!!!
  127. S1 anti roll bar or RS 1600i anti roll bar?
  128. what dizzy for cossy mangement for rst
  129. oil pump
  130. rear disc
  131. Engine Timing
  132. are mk3 escort inner sills the name as mk4?
  133. idle problem
  134. Series 1 and series 2 Turbos, are they different?
  135. Brake set up
  136. Where to buy B&M Quickshift ??
  137. CAN I USE COSWORTH LOOM?????
  138. eibach springs
  139. how to tell an lsd box help needed thanks
  140. What use recomend for my next mod ?
  141. breaking s2
  142. 5th injecter
  143. Floor pans where do i stand
  144. gotech management
  145. B&M Shortshift
  146. new to passion ford
  147. suspension inquires
  148. series one problems help please urgent!!
  149. advice please?
  150. mk3 locks
  151. 3 or 4 point harness for recaros?
  152. mf2
  153. New S1 Owner
  154. New interior Mk4 Escort ... 90 Spec ?
  155. oil mixed with water in boost pipe f*cked turbo seals ??
  156. electric prob
  157. mapped ecu's???help
  158. ERST wont start :(
  159. ERST gearboxes, need help........
  160. rs turbo high reving
  161. Maniflod/throttlebody
  162. mk 4 rear bench same as mk3 fiesta ? ? ?
  163. amal valves
  164. anyone remember this?
  165. Erst cuts out
  166. Exhaust dilema
  167. series 2 pissing me off!. valve troubles i think?
  168. fuel pump bracket
  169. headlights
  170. Cam fitting
  171. ka cutting out when driving on motorways or high revs
  172. s2 erst fueling problem
  173. escort and saff T3 differences?
  174. oil pressure light
  175. should i? should i not?
  176. S2 RST Roll Cages.
  177. wer 2 get a adaptor plate for frst engine on mfi set up
  178. DOOR LOCK PROBLEM!!!!!
  179. Koni Refurb
  180. registering a rebuilt Escort..what do you think ??
  181. smaller turbo
  182. Rear arch replacement??
  183. reg plate
  184. Headlamp retaining clips......
  185. Shells and Rings
  186. Weak floor pans on all RS Turbo's
  187. mk4 cabby boot. broken lock
  188. Is this an S1 Centre tray
  189. pe 1.9 phase 2 piston ring
  190. oil
  191. engine differences?
  192. superchips
  193. new rear arches
  194. 1.9 crank and pistons
  195. Help Please s2 rst fuel
  196. PF General descussion
  197. fuel computer
  198. nosey insurance company
  199. flywheel machining
  200. heat wrapped manifold ???
  201. s2 alloys
  202. metering head/injectors
  203. engine rebuild
  204. help zetec turbo Coolant Hoses
  205. looms
  206. Polyurethane Bushings
  207. valve springs
  208. my old RS on ebay
  209. pic request please urgent
  210. Failed MOT ....... Resto time!!!!!
  211. adaptor plate for fiesta turbo head on mfi?
  212. any one on hear own g717pdh (iv sorted now pleas read)
  213. glowing manifold & turbo
  214. How to tell if my S2 has an LSD or not???
  215. relays
  216. cam help ?
  217. Kent cvh 34 cam timming?
  218. 4 to 5 psi boost
  219. Offset woodruff ?
  220. will a T3 actuator and bracket fit a T34??????????
  221. WHO OWNS B917BVW NON CUSTOM SERIES 1?
  222. Throttlebody
  223. size of the
  224. gearbox cradle
  225. Fighting with my FMIC, grrrr.....
  226. efi
  227. 17" or 15" - which is better for performence?
  228. Thread from oil sensor
  229. escort 16 ghia to a turbo
  230. fix or another engine?
  231. gearbox mounting bracket
  232. what HT leads?
  233. Cam
  234. Breaking rs turbos
  235. escort rs turbo ecu
  236. My new car
  237. Should i
  238. stolen white rs turbo.. Also cabrio stolen & now an xr3i
  239. Fitting escos wheels on mk3-4
  240. Rev counter....omex 600
  241. only seems to boost in 1st gear
  242. Oil cooler
  243. Sierra crank pulley on ERST
  244. Are these s1 water pumps?
  245. any1 fitted an oil cooler to a s2 ?
  246. flywheel
  247. no compression in number 3
  248. Compression test!
  249. hydrolic clutch
  250. help guys plz!!!!
