gearbox removel/reffitting
23-12-2007, 08:15 PM
can anyone tell me the easiest way of removing the gearbox from my rs turbo,hoping to do iti later in the week, gearbox blown got a new 1 to put in just need a bit of advice.any help welcome,cheers.
23-12-2007, 09:01 PM
420
if its a series 2, unbolt it from the engine, undo the the cradle bolts n drop it out...
24-12-2007, 12:19 PM
as easy as that then? you reckon it can be done in a day with fitting a new clutch aswell?
24-12-2007, 12:30 PM
Easily done in a day fella.
Your ABS will cause you the most fun, that is if you still have it fitted.
Escort Cabriolet Owner
yes and its easier fitting clutch at the same time than doing it afterwards trust me on that one
27-12-2007, 03:30 PM
yeah abs still fitted,big problem??
27-12-2007, 04:01 PM
not a major problem just make sure belts are all alignned as you put it all back together again
27-12-2007, 04:38 PM
righto m8,cheers for the help
28-12-2007, 06:58 AM
If your taking the engine out aswell it might be worth ditching the ABS ??
chowfornow
14
05-01-2019 09:01 PM
mjonathan24
29-10-2015 10:39 PM
Turbo1994
Ford Escort RS Cosworth
17-10-2015 10:32 PM
Iain Mac
30-09-2015 09:39 PM
gingeRS
04-09-2015 06:29 PM
