s2 alloys
06-12-2007 | 10:35 PM
s2 alloys
whats the biggest brakes i can fit under s2 alloys
06-12-2007 | 11:11 PM
the easiest ones to fit under standard wheels are cosworth ones
06-12-2007 | 11:22 PM
07-12-2007 | 05:47 PM
Quote:
Originally Posted by orion turbo
285mm discs under 15s
will i need bigger calipers for them?
07-12-2007 | 05:52 PM
i had a 285mm cossie 4 pot conversion under my 15's
bit of a squeese but looks awesome
07-12-2007 | 05:58 PM
where would i get them from
07-12-2007 | 06:50 PM
Ive just converted my S2 dailey driver over to cossie 2wd discs and standard calipers and good pads!
Dont get me wrong it isnt going to pull your eyeballa out of your head type of stopping but it was a noticable difference especially on low speed braking.
About a cheap as you get as well!
07-12-2007 | 07:30 PM
07-12-2007 | 07:52 PM
4wd calipers
2wd discs
i didnt really notice any real difference in stopping power compared to standard size though
07-12-2007 | 08:08 PM
07-12-2007 | 08:10 PM
Size makes not a lot of difference to stopping performance, only aids cooling.
What pads do you run ?
07-12-2007 | 08:22 PM
just want a disk to fill teh gap thats all
07-12-2007 | 08:32 PM
Take the caliper off and put a 335mm one in then
Or do the 2wd conversion as above for cheapness, wont stop you much better but it will fill the gap.
08-12-2007 | 10:07 AM
is it not the cossy 4x4 that runs the single pot caliper and the 2wd that runs 4pot?
08-12-2007 | 03:35 PM
or u could use the 4 pots of a cossie
u only need the 4wd calipers if ur using s1 wheels
08-12-2007 | 08:34 PM
so what cosiie calippers and disks fit
08-12-2007 | 09:21 PM
09-12-2007 | 04:39 PM
10-12-2007 | 12:05 AM
Cosworth Conversion will fit under 15's
01-11-2015 06:53 PM
07-10-2015 12:56 PM
Fudgey
21
30-09-2015 06:19 PM
Alloy wheels and ICE for sale
28-09-2015 06:19 PM
