Brake set up
Brake set up
Hello guys,
I hope you can help me, because most of the guys in the netherlands are unclear and i don't know it anymore.
I wanted a brake upgrade on my rst s2 so in the netherlands they told me just buy cossie brakes they are all the same and you can fit them easily.
So i bought a set of cossie brakes, but afther that i found out there are differences between them en some use washers and other take 1 mm of there brake discs.
So here's my question. What brakediscs do i need to order and what adjustments do i have to make?
here's a picture of my calipers i don't know if you are able to help me with only the picture but i worth to give it a try
Also for braided brake lines why do the always supply 4 brake lines? I have the car now a year in parts and i can only remember the front brake lines that i can changes for braided? but do i need them from a cossie now or just for the escort?
Cheers guys!
Cheers guys!
Hi,you need Cossie 2wd dics's now that you have Cossie 4X4 calipers.As for briaded hose's ,order some off Mike Rainbird who is on this site.Regards,Micky
and do a need the blocks from a 4x4??
ok sorry! this thread can be closed then!
The problem was i didn't know these were the cossie 4x4 calipers! i just brought them as cossie calipers
Was when i just started working on the car
3dr cossie
Alloy wheels and ICE for sale
02-09-2015 08:58 PM
