Compression test!
Old Dec 1, 2007 | 12:13 PM
Dumpy's Avatar
Dumpy
Default Compression test!
What PSI should my pistons be at when testing through the spark plug holes??
Cheers,
Dumpy
Old Dec 1, 2007 | 03:25 PM
Dragsteer's Avatar
Dragsteer
If I remember good all under 120 psi are OK , but best results are about 150 psi.
My car have about 10- 10.5 bar on all cylinders
dont forget to remove all spark plugs and disconnect (electric) plug from dizzy
Old Dec 2, 2007 | 01:11 AM
Billy_RS's Avatar
Billy_RS
That dont really make sense mate.
Under 120psi = Good
About 150psi = Best
Sure thats right?
Old Dec 2, 2007 | 07:20 AM
antony215's Avatar
antony215
Escort Rs Turbo
Anything around 160psi is a good compression. The manual says it should be between 12-14 bar but that aint going to be the case for a 15+ year old car
Old Dec 2, 2007 | 08:21 AM
turbodan's Avatar
turbodan
the thing to check for is that all cylinders are the same
Old Dec 2, 2007 | 10:26 AM
TuRbO-CaB-LaD's Avatar
TuRbO-CaB-LaD
checked mine yesterday, 125 psi except numba 3 it had nothin!!
Old Dec 2, 2007 | 10:28 AM
s2 ben's Avatar
s2 ben
nothing as in 0 what have you done
Old Dec 2, 2007 | 10:32 AM
swerv's Avatar
swerv
thats the main point there well within 10% or so of eachother
Old Dec 2, 2007 | 06:34 PM
sm's Avatar
sm
u have proberbly cracked/holed no3 piston, does it smoke when u start it?
had exactly the same on my s1 a few months ago so i took the bottom end out had it stripped and checked and had cracked no3 piston on the side and the rings also
so i had all the other parts checke and all i ended up needin was one piston a set of rings and a set of bearings and now have 175psi across all four cylinders
Old Dec 7, 2007 | 06:41 PM
Dumpy's Avatar
Dumpy
Bugger, mine are running different PSI's across them all, and between 60-80!!
Looks like i'll be stripping her again, do you think its thr piston rings then??
Cheers,
Dumpy
Old Dec 7, 2007 | 07:35 PM
turbodan's Avatar
turbodan
could be valves not seating properly
Old Dec 7, 2007 | 11:55 PM
TuRbO-CaB-LaD
i hope it aint pistons or rings,ive had the head off, no holes on top of piston didnt check side, there no scores in the pot, i was hopin it was a fcuked valve or faulty injector, as it idles at 400rpm an struggles to move
Old Dec 8, 2007 | 11:29 PM
Chris69's Avatar
Chris69
approx 170 to 200 psi on the 12 to 14 bar
hope thats not right as my nwely built 1600 only has 150/155 on each cylinder
Old Dec 10, 2007 | 12:10 AM
Billy_RS's Avatar
Billy_RS
Need an expert to give an anwser really
Old Dec 10, 2007 | 04:40 PM
Moonie's Avatar
Moonie
You cant give an exact figure with regards to cylinder pressures as each engine will vary even if standad. As said above you want to be seeing roughly the same compression on each of the 4 cylinders. Whats your reason for checking the compression's? Are you just checking the general condition of the engine of is there a misfire?
You want to....
1 - Disconnect black electrical plug from distributor
2 - Remove al 4 spark plugs
3 - Conect compression guage
3 - Either get someone to hold the throttle 100% open or wedge the throttle open.
4 - Crank the enge over and take not how many compression strokes it takes to read the highest figure. (Each time the cylinder is on its compression stroke the guage will rise).
5 - Repeat for the other 3 cylinders
As mentioned earlier the manual states around 12-14 bar but this figure will decrease with engine wear/mileage. You just want to be seeing good even figures across all 4 cylinders.
Old Dec 12, 2007 | 05:49 PM
phill295's Avatar
phill295
i normaly say anything from 150psi to 190 psi is good but anything under 100psi somthing is wrong
TPM961
Jan 15, 2018 10:50 AM
Prickly_buzz
Dec 7, 2017 09:52 PM
tankybaby66
Feb 6, 2016 02:24 PM
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
