2.9 V6
Im planing on changing the engine in my P100 from a 1.8td to a 2.9 24 valve V6 granada.
Are the engines in a automatic granadas different to the manual engines?
Whats the best gearbox to use?
Will I have to drill a new hole for the gear lever?
What Bhp is a standard engine puting out?
What do people do for fuel pumps?
i always use a v6 type9 (they have the longer shaft)
oem bhp 195/205
cosworth fuel pump will do
they go really well with bob cams vectra v6 injectors and a 50mm exhaust and 3 good box's and if the p100 is the same set up the stick go's to the same place.check out fordpower loads off good info there mate
Resident Wrestling Legend
everything else is a virtual bolt in and job done job
Indyrs
20
01-09-2015 09:04 AM
