Emissions Help please
Old Dec 31, 2007 | 07:52 PM
Bungle's Avatar
Bungle
Default Emissions Help please
Right my car has failed the mot on exhaust emissions can anyone tell me a way to turn them down please? cheers, Grant
Old Dec 31, 2007 | 07:54 PM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
and the car in question is a... ?????
or more importantly powered by what engine
Old Dec 31, 2007 | 08:29 PM
1.9 xr2 on 40's's Avatar
1.9 xr2 on 40's
st170 breaking
adjustable on the top of the meterhead, for mot it shud be about 3% i think, i set mine to 3.5
you cant just do it, its gotta be done on a tester
Old Dec 31, 2007 | 11:07 PM
Bungle's Avatar
Bungle
Thanks mate i take it this is the allen key screw???
Old Dec 31, 2007 | 11:08 PM
Bungle's Avatar
Bungle
Sorry is this not the ESCORT RS TURBO ROOM
Old Dec 31, 2007 | 11:20 PM
Turbocabbie
Top Cab !!
Sorry but do people not run OFAB, Gotech, Cossie, Megasquirt or different management systems on their RS Turbos on this forum
As I expect you are aware having a ZVH in your signature many FWD Escorts on this forum are not standard
Is it not better to clarify things rather than provide incorrect advice or to make assumptions
Old Dec 31, 2007 | 11:50 PM
gkandr4ch's Avatar
gkandr4ch
Well I presume it isn't an efi.
Old Jan 1, 2008 | 08:28 AM
Bungle's Avatar
Bungle
Lol no worries its still on mfi anyway
Old Jan 1, 2008 | 10:26 AM
B1G_RST's Avatar
B1G_RST
had a problem gttn my scooby thro it mot fail on emmisions also,
check if you exhaust has any leaks at the joints ect
take the car for a blast on a (privite road) and kick its hole,
also you can get carb/injection cleaner from stores like halfords, spray that into th inlet,
i did all off the above and the scooby passed its emisions,
Old Jan 1, 2008 | 11:02 AM
swerv's Avatar
swerv
that wont work on an rs turbo, that will be for cars fitted with cats to get them hot.
pull dipstick slightly out when emmisions are being done this will bring it down to pass
Old Jan 1, 2008 | 12:03 PM
Bungle's Avatar
Bungle
WTF seriously??? How do you know that?
Old Jan 1, 2008 | 01:08 PM
B1G_RST's Avatar
B1G_RST
this wil lose exssess gas thro th dipstick,dont htink this wil work tho,and the carb clean cleans the injection system not th cat,
Old Jan 1, 2008 | 05:45 PM
swerv's Avatar
swerv
i wasnt on about the cleaner, the bit about taking it for a blast, ive done this lots of times to get through emissions on newer cars.
if you make a small air leak the emissions will come down, too much the car will stall
dipstick was just an example you could use breathers, oil cap etc.... saves you messing about with the co adjuster without the correct equipment.
Old Jan 3, 2008 | 10:02 AM
Bungle's Avatar
Bungle
Well i turned the emissions down and pulled the dipstick out a bit for good measure and it passed WOO
atm
Sep 7, 2015 05:39 PM
borboyous
Aug 22, 2015 11:17 AM
Old ford
Jul 31, 2015 06:50 AM
Cowboi
Feb 12, 2006 07:41 PM
MADMATT
Sep 1, 2004 11:33 AM
