Cam
focus rs 1672
Originally Posted by Benxrrst
Ok cheers wouldnt mind newman but a bit pricey.
Newman cam itself is actually cheap at £110...it's the lifters that make them seem a bit pricey!! However, having gone through 2 kent cams in the space of 1,500 miles i wouldn't recommend anythin else bar the newman. Lifters are a bit fiddly to setup but worth it imo, wouldn't say the profile is any better than others but seem to last longer for sure
i run a Kent cvh 35 and its been in the engine for 4 over years and done over 10k miles with no problems at all! top end is still lovely and quiet too!!
focus rs 1672
Originally Posted by T28 RST
Ive had my Newman cam since March 2003, lifters have been adjusted once.
Its covered roughly 18000 miles and seems to be fine
Originally Posted by rstdave
turbodan: 245bhp at the flywheel mate at the mo.....the car's in the next issue of fast ford at brunters if you wanna have a look at the spec
top work fella some impressive times you did there
car looks awsome too
just read it mate mag was on the mat this morning
car looks awsome too [/quote]
Oh yeah...i haven't bloody got it yet lol...not out in the shops till tomoro so i better go get it then!!! Cheers for the positive comments, not the quickest by a long shot but not too bad considering only the mapping was done a by a known tuner, and i was a good 50bhp down on everyone else there that day lol!!
My Kent CVH35 is heading up for 20k miles now and is still as sweet as the day it was fitted.
Due to the horror stories I would be inclined to go for a Newman cam but between the Piper and Kent for this application the Kent wins hands down.
i used to have a piper t2 and after bout 20k miles they start to rattle
newman cams all the way there lifters are only expensive cos there solid lifters and the cams are made of a special grade steel not like the piper and kents
i am in the same problem which cam to go for ,
Also, newman cam are too wild for the MFi. You'll need proper management. Don't know about the FRST ecu...
quote from fiestaturbo.com
is this true????
is this true????
focus rs 1672
is this true????
is this true????
Mc5506
05-10-2015 09:57 PM
