no compression in number 3
Old 01-12-2007 | 01:23 PM
TuRbO-CaB-LaD's Avatar
TuRbO-CaB-LaD
Default no compression in number 3
was driving my car hard last night, this mornin it decided 2 run like a bag of shit which got worser n worser, changed plugs n leads, did compression test an number 3 has nothin, do u think it cud be a head casket or burnt out valve? i jus had it set up 2 days ago cheers
Old 01-12-2007 | 01:31 PM
orion turbo's Avatar
orion turbo
does the car smoke at all??
Old 01-12-2007 | 02:44 PM
TuRbO-CaB-LaD
no smoke at all
Old 01-12-2007 | 03:00 PM
orion turbo
is there any drops of water or anything coming out of the exhaust
are you losing any fluids
Old 01-12-2007 | 03:13 PM
TuRbO-CaB-LaD
nope no water out exhaust, was bit low on oil jus topped it up
Old 01-12-2007 | 03:16 PM
orion turbo
piston ring , head gasket or valve stem oil sills
there the only thing i can think of.
Old 01-12-2007 | 03:23 PM
TuRbO-CaB-LaD
hope it aint piston ring lol
Old 01-12-2007 | 04:11 PM
orion turbo
sound expensive
what rings and pistons u got?
Old 02-12-2007 | 01:08 AM
Billy_RS's Avatar
Billy_RS
Wont be that bad. Rings are about £60 then fitting them is a day job, depending on skill level.
Old 02-12-2007 | 06:43 AM
Badman38's Avatar
Badman38
Default Re: no compression in number 3
could be your head gasket burn'nt between the cylinders or valve i doubt very much its the rings.
sean
Old 02-12-2007 | 10:24 AM
TuRbO-CaB-LaD
cheers hope it is a gasket, soon now monday morning cheers
Old 02-12-2007 | 04:41 PM
orion turbo
sean
it carnt be the head gasket burnt out between the cylinders coz he says its only 1 cyl with no comp if its burnt out there would be 2 cylinders with no comp
Old 03-12-2007 | 07:27 PM
TuRbO-CaB-LaD
took head off 2day, valves n pistons look ok, gasket had snapped, replaced it, put head bk on, did compression test, all 4 are ok now, but it still runs terrible on tick ova at 400 rpm, i dare not drive it, do u think it cud b a hydraulic?
Old 03-12-2007 | 08:36 PM
orion turbo
have u timed it all up right
Old 03-12-2007 | 09:08 PM
Badman38's Avatar
Badman38
sean
dam what was i thinking sorry
sean
Old 04-12-2007 | 07:15 AM
TuRbO-CaB-LaD
i had it set up last thurday on dyno he adjusted the timing then, will i need timing adjusting again since the head bin on an off agen cheers
Old 04-12-2007 | 04:12 PM
Moonie's Avatar
Moonie
If you have moved the position of the distributor then the timing will have changed. It allways a good idea to get it checked anyway.
Prickly_buzz
07-12-2017 09:52 PM
01-11-2015 06:53 PM
Fezman1
02-10-2015 01:22 PM
rsguy
44
29-09-2015 03:29 PM
gambo08
Fiesta RS1800/RS Turbo
16-09-2015 08:10 PM
Quick Reply: no compression in number 3
