View Full Version : Ford Escort RS Turbo
- advice
- How wide are escort cosworth alloys???
- has anyone had any probs with . . .
- Budget Zetec turbo
- amel valve (sp)
- Roof lining
- Anyone got a 1.6 cvh on 2wd or 4wd T3 cossie turbo???
- PJ Motorsport!
- st 170 turbo vs silver top turbo
- Brakes Upgrade for RST
- Amal and bleed at same time ?
- for sale nokia n95............$300usd
- Just started my first EFI conversion job!
- suspension alinment
- anyone know of my car
- alarm siren help
- Chipp ECU question?
- Just Took The Series 2 For M.O.T
- A knock from nearside... Could it be a bush???
- rst is ROUGH AS HELL HELP
- Ignition Barrell
- any one else get worried wen going to the rollers
- Tax Disc Holder
- 5th injector kit
- which shocks?
- RANDOM QUESTION
- Boost Problems (Please Help lol)
- Random pics of my motor
- FAO lucid
- s2 bonnet
- rear disc question..
- muffler question
- Fuse Box
- pics of your S2 enterior styling
- S2 Rad's
- Any pics please of S1's or S2's with Mudflaps
- Are the S1 Tca's diffrent to the S2 one's
- Cheapest way to upgrade brakes
- fao people with removed abs
- What Nuts to use................
- standard intercooler
- whats the best running in oil????
- Cylinder head parts numbers
- FAO people with rear discs
- RST overheating when switched off?
- wanted series one rs turbo kit
- s2 coilover suspension kits
- alloys
- quick loom questions
- rs turbo any recent project pics or any pics
- starter motor heat shield
- coil pack conversion
- amal valve pipes-which way??
- Which Intercooler
- insurance, what a rip off !!
- Decompression Plates
- head bolt washers
- Squeaky, poxy, pain in the aŁ@e parcel shelf - help needed!!
- Shortened Dampers
- TACKY OR NOT!!!?????????
- Is this a limited slip diff
- a couple of things
- tap tap tap
- Help needed with this weird BOSCH part (fuel unit)
- 280mm or 320mm steering wheel
- weilding
- Seat Runners?
- Logo Escort RS turbo
- fitting anti-roll bushes
- fitting dizzy-fitting it and getting car running!
- best spark plugs for series 2
- the best after market management
- timing
- bricking it........MOT passed, woohoo!
- Esc cos rims are on the S1 **UPDATED WITH PICS**
- Magnex Exhausts?
- Help! Front or rear jacking point covers???
- Usual oil consumption?
- rs turbo rear anti roll bars
- Hi all, newbe with modded S2 says hi.....
- thermostat housing
- hand break cable
- Running lean/timing out??
- G-Max VS Koni
- zvh in a S2
- ! Urgent ! After some part information ...
- Brake pedal pressure - where have you gone ??
- What Gearbox oil to use?
- quick one
- On a mercury RST ?
- oil pressure gauge readings...
- turbo spins up slowly and boost is all over the place
- ***BLACTOP ZETEC TURBO***
- vecta alarms
- Drag slicks
- s1 ignition barrel
- REBUILDING METERING UNIT??????????????????/
- Launch Control
- who is runnin a t28 on a low comp bottom end
- Oil filler cap blew off...?
- amal valve
- over heating
- Help
- please help
- Gauge In Coin Tray - S2
- MOT
- suspect fuel pump
- Mk6 6 clutch pedal
- turbo spins up late, about 4200rpm?
- When you buy a new stainless exhaust do you get...
- yyyyyyyyy
- Variable speed wiper stalk
- quick question, Help!!!
- can sambody send pics off rst rear antirollbar.
- Petrol gauge problem???
- central locking problem
- alarm
- Gear box oil
- Pulley for CVH34
- s1 turbo headlights carello or lucas
- 2lt zetec bottom end
- Ford racing oil pressure gauge fitting
- rst s2 heads
- Turbo Q
- Can someone tell me what these old school stickers are off?
- Speedos stopped working????
- airtec intercoolers
- please help with a little part!!
- What to look for when buying a S1 RST
- Alloy wheel advise needed!!
- gotech
- silver top or black top zetec turbo
- where to get kit like this?
- Steering Wheel Questions
- RS Engine Rebuilding
- Shall i break my s1
- help!
- Heated front screen
- new fuel sender and fuel/temp gauge available from ford?
- rs2000 handbrake cable help
- oil pressure drop
- Turbo Chatter
- Gauges - Whats more important?
- whats needed for rear disc converson?
- s1 spotlamp wiring
- adjusting koni sports suspension
- Turbo Oil Feed
- Needed Mechanic.......
- Sticky calliper handbrake lever
- Pics of 40mm drop
- S1 turbo starting problem
- Rockers
- Starting / Fuel issues
- S1 Main Dealers
- new on this site
- rosso red paint paint code
- How thick is the RST std headgasget?
- Mk 5 Pedal mod gone wrong.... (really wrong)
- rst vs mk3 golf vr6
- Whats the name?
- URGENT - Water leak.
- The New Series 2 Database
- series one tow eye
- your escort turbo and zvh
- felpro head gasket discussion
- pic of mine as reqested
- any pics of stripped/race prepped interiors?
- you all say the cometic headgasket is crap but why?
- cheap mfi injectors
- My S1 sold
- Soon to be back in a RS Turbo
- scheming!!
- 50mm Lowering Springs
- Door Card Clips....
- mtx gearbox conversion
- FAO Alex_86
- Turbo spec ?
- Fuel pump??
- boost controller question
- fitting popout rear windows on a mk4 escort
- engine building
- in need of a clip
- Wire for starter motor
- How do i wire up gauges?
- Whats next?
- Ride Height!!
- efi parts needed
- Ignition barrel sticking
- Clutch for 250bhp ?
- s1 intercooler/ bhp
- whos on std wheels, tyres sizes?
- Another prob with the S1 :cry: *sorted update*
- Kent CVH31 Camshaft
- ST170 front brakes on RST - braided hose issue!?
- s2 front mount GRS intercooler into s1
- s2 / xr3i relays
- Manifold Gasket
- chiped or not??????? need answers
- Oil Tempreature
- Vernier Pulley
- wot type of uprated pistons availble for 1.8 zvh turbo?
- Fan Plug Wiring
- boost guage holder
- ported heads
- RS7 Softspokes 4, 7.5j x 17" ET38 offset on a series 1?
- wheel not straight
- is it ford nite tomorrow at ace cafe?
- KENT CVH35 Camshaft
- uneven ride height
- S1 rs turbo clear/smoked rear lights
- Ford Motorsport turbo manifold ???????
- KE-Jet tuning
- Head gasket
- Ignition relay
- Not going into gear!
- oil in boost pipes
- Testing for a good spark
- lean over 2.500RPM
- Help needed: Removing ABS from a series 2.
- carbon fibre bonnet
- mintier than mint
- another boring efi question for you safechav
- MOT pass
- brakes
- we need your pics - Limitless Tuning
- anyone any help
- No oil to the turbo?
- mfi air filter relocation
- Fuel & starting issue
- plug gaps
- chip identification
- ecu identification
- lancia managment
- flowed metering unit
- I need a gearbox NOW!!!
- Weight of a S1/2 gearbox ?
- series 1 recaro's
- Cheapo Quickshift ????
- Efi conversion, using xr2i?
- psi on 1 turn of -34 actuator
- Cossie TB
- Front Suspension Top Mounts
- cutting baffles out
- gauge pod ?
- what chip?
- what size thread on egt bung on turbo housing
- EFI conversion
- smoking
- EFI Throttle cable......
- sierra 1800 36-1 triggerwheel mod
