cutting baffles out
cutting baffles out
what performance affect does cutting the baffles out from the back box have on a car(apart from being a bit loud)
and would this affect the turbo as surely there would be less back pressure
Not really going to make a lot of difference at all, possibly if you were looking to go one better than Christians car, but still probably not
Who sais you need back pressure on a turbo car
how else does the oil stay in your "dynamic seal" turbo
Don't mention ze Vor
Been there, done that.
Don't think it'll make much difference power-wise. And regarding the sound... Well, I've removed all the glass wool from a std silencer once and it wasn't loud at all. Most people wouldn't have noticed a big difference I think. It's quite amazing how much of the noise is absorbed by the turbocharger.
There are ways around it but standard turbos dont always beneift from big bore exhausts.
Different turbo's have different seals, there are T3's that have the carbon seals or whatever they are called, but RST ones use the dynamic seal, so its basically a piston ring, and simple physics keep the oil in place (exhaust pressure exceeding the oil pressure to contain it)
bigger bore exhaust = less pressure in the exhaust than the oil pressure, which in turn = oil leaking through the seal
A step gap seal means there is no direct gap through the seal
Mark RS
12-10-2015 06:01 AM
07-10-2015 12:56 PM
