gotech
just finished my gotech install started her up after breaking a piston about a year ago
wasnt all that difficult cept the installation manual is a piece of shite!!!!
if anybody wants to know how , contact me at stevenb@denorco.com , cos it seems your tuners are the same as the ones down here - wont help unless you got wads of money....
will be running it in over the next few weeks and then having it dynoed at Gotech themselves - and i will be making the map available for all at no charge
hoping to make at least 180kw at the wheels @ 1.5 bar
my spec as follows:
golf 1600cc pistons 80.895mm
500cc injectors
T3 .48 hot t4 .60 cold dash 23 wheel
block chopped 4mm
rods polished and bushed with vw beetle bushes
gotech v5 standard
golf tp100 module
lucas dizzy locked and hall sensor installed
arp rod bolts
cr 7-1
efi head and cam
log style cast manifold
cheers
my spec as follows:
500cc injectors
block chopped 4mm
gotech v5 standard
golf tp100 module
arp rod bolts
cr 7-1
efi head and cam
cheers
