Starting / Fuel issues
Right im sure this has been asked about a million times before and if it has please just point me the right way ive tried searching but to no avail
Right my little Series 2 RS Turbo is having problems starting
the fuel pump primes , there is fuel and pressure right up to the fuel distributor , there is pressure up to the cold start valve , but nothing at the injectors , i crackd on off the pipes off and turned the engine over , no fuel at either or the ends , good oil pressure , decent spark (tested before i got fuel everywhere) it had been stood for a couple of months outside and its had a head gasket replaced in the last week.
Any help would be greatly apreciated
Under your dash, on the passenger side, you will find a pink rele (Spelling?), take it out, and use a short wire to bridge the two big wires.
This will make the fuelpump stay on.
Now, press the paddle in your metering unit down, and at the same time open one of the fuelpipes on the metering unit.
Hopefully you will now have fuel at the screws, so do it on all the pipes, replace the pink box, and of you go
You won't see any fuel out of the injectors unless the flap moves down, and being as you've removed the injector(s) you have introduced an air leak into the system = no fuel spraying
Originally Posted by PeterRST
Originally Posted by StuarTurbo
will do , suppose thats what i get for payin Ł400 for one
Yip been stood 6 months , lad cooked the head gasket took it apart to do then bought a scooby , wanted it off his garden so i snapped it up on the cheap
Would have to be a fairly sizeable leak i reckon.
The whole inlet system and engine itself are potential air leaks, so could take a while to find it, if thats what the problem is
borboyous
22-08-2015 11:17 AM
ekjim
17-08-2015 08:57 PM
CabrioTurbo
01-08-2015 11:04 AM
