Replace orig. ECU with Gotech unit
I am about to replace the original ECU with a Gotech one from Jamsport. But i am not 100% sure if it is the ECU with the white or green label i have to replace with the Gotech.
Looking at it yesterday shortly, i think that it is the one with the green label, but just wanted to ask some PF´if is the right one.
And where have you installed the ECU ? same place as the orig. or somewhere under the dashboard ?? (Gotech manual says somewhere dry )
Henrik
Henrik
powered by K26
i take it your still runing the MFI set up then?
yer they replace both, as when gotech is fitted youll be running efi and wont need them.
and sick it in your glove box, thats where mines going.
OK thanks
The engine has already been converted to EFI and i do have the new loom and Gotech ECU, but for some reason the 2 old ECU´s are still in the car.
They will be removed asap.
JK12
33
26-04-2021 12:09 PM
NC53
13-09-2015 03:05 PM
