final gotech question, nearly there!
i have fitted a gotech mfi to my s2 its all sorted and after getting over a few problems it starts and runs but only for a few seconds because there is no signal from the gotech to the fuel pump, it will prime but not pump after the engine is started, basically i need to know what and where to connect the gotech to the fuel pump, can you trace the wires from the pump relay in the fuse box and tee into the switched ignition to the ecu? i spoke to simon at sitech and he was very helpful just need to know for sure really
thanks
joe
thanks
joe
hi thanks for the reply i have reconnected the two green wires to the coil negative and it still does the same, i can hear the pump prime and it seems to just run on the fuel primed into the fuel rail for a few seconds, does the signal go through the coil negative? any help please its doing my head in now
cheers
joe
cheers
joe
07-10-2015 12:56 PM
