amel valve (sp)
Old 14-06-2007 | 07:48 PM
juffer's Avatar
juffer
Default amel valve (sp)
i have been told you can half you boost by adding a switch to the amel valve. is this true? if it is which wire would you break to put the switch in. also what do you do about haqving it set up, on or off ect.
cheers
Old 14-06-2007 | 08:01 PM
juffer's Avatar
juffer
the reason why i am asking this is because i want to run a high boost about 20 psi. i dont want to run this pressure all the time and i dont want to mess with a bleed valve.
Old 17-06-2007 | 06:44 AM
MarkXr's Avatar
MarkXr
This is true. There's a constant live on the valve and a (ECU)switched earth.
When the ECU detects parameters to be hazardous to your engine it breaks the earth to your Amal valve thus lowering the boost.
When you line up a switch in the earth you can manually switch off the Amal valve like the ECU does in "safe mode".
Obviously you have to set the car up on high boost.
Old 29-06-2007 | 02:33 PM
-ERSTtrackproject-'s Avatar
-ERSTtrackproject-
what is the 'safe' mode boost setting?
Old 29-06-2007 | 03:25 PM
juffer's Avatar
juffer
the 'safe mode' is just the ecu will half the boost.
Old 29-06-2007 | 03:57 PM
-ERSTtrackproject-
so if you have the boost at 30psi it will cut it to 15, 20 to 10 and so on?
Old 29-06-2007 | 04:21 PM
zippyobrien's Avatar
zippyobrien
yep
01-11-2015 06:53 PM
DAZZER
30-09-2015 08:43 PM
fordrallycar
30-09-2015 07:57 PM
RS-Rikki
21-09-2015 07:27 AM
rs_jim
19-09-2015 08:41 PM
Quick Reply: amel valve (sp)
