How do i wire up gauges?
alright hows it going i just bought some gauges and haven't got a clue how to wirer them up
iv got a volt vacume and oil presher gauge. the volt gauge has a black/red/green/white and orange
oil presher has all of the above
vacume has black/white
I know the white is for the lights coz i tryed it so the vacume is easy enough. can anybody tell me where the vacume pipe goes. any pictuers would help alot. im pritty good with the machanical side of things but when you got a bunch of wires in you hand and you dont know where thay go it can be a nightmare
thank for looking
chris
thank for looking
chris
i dont have the manual thay are second hand. if anyone else has any advice it would be a great help the volt and oil presher are f&f
thanks again
chris
thanks again
chris
orange will be swtich live for the when you put the lights on,
yellow will be perminent,
red will be ignition switch live,
green wire will go to the white wire on the pressure sensor, then you ground the other wire from the pressure sensor
not sure why your volt gauage has a green wire,
and tbh, there is no piont what so ever fitting a vacume gauge to an rs turbo, wont tell you any thing, and will probly leak under boost
hope this helps
hope this helps
Mark RS
12-10-2015 06:01 AM
wheelwizardrefurbs
22-09-2015 05:45 PM
