Cheapo Quickshift ????
Has anyone any experience of the Rally Design quick shift kit ???
At £45 how does it stack up to the £220ish B&M shift kit ???
http://www.rallydesign.co.uk/catalog...oducts_id=2011
S1 Database Editor
Me. Personally I couldn't fault it.
have a read of other thoughts here....
https://passionford.com/forum/viewto...9d18b32f1e6649
https://passionford.com/forum/viewto...885864#3885864
The gate for reverse, which mk4's don't have on the linkage
its a simple concept, the end result will be largely influenced by how fucked (or not) your linkage already is
S1 Database Editor
juffer You can make it fit a mk3, but you would have to modify the RD sandwich plate.
c.fogarty About right mate. Not had a go with a B&M item so can't comment but certainly don't dismiss the RD item.
Originally Posted by juffer
it says i wont fit mk3's. i thought they were all the same? whats the difference?
On a Mk3 the gear stick runs in a plastic gate in the bottom of the housing, as well as through the bearing itself.
The Mk4 item dosn't have this gate in the plastic housing.
Picture is of a Mk4 housing - if you look a a Mk3 housing it is around about another inch deeper (bigger)
The B&M (the dearer one) comes with a new gear stick of the correct length, (ie not a nasty cut and shut one) but at the end of the day it just uses the same basic principal of moving the fulcrum point of the gear lever upwards to create a quicker shift. It also has a new billet alloy top mount etc.
220TC
14
28-08-2004 03:45 PM
