Gear box oil
filling hole is on the front of the box, is a small plug that you undo with an allen key.
i had to bodge together a load of hoses and a funnel to get oil in it lol
no idea about the oil though.
I asked the same thing the other week:
https://passionford.com/forum/viewtopic.php?t=267991
Fill plug is on the front of the box, 20mm diameter grub screw type thing (Allen key to undo).
There is no drain plug... Best to pull a driveshaft out and drain it that way. (Unless its already out of course)
Marc LJX, To drain the oil out the box you undo the selector shaft cap nut, remove the spring and lock pin and bobs your uncle fanny's your aunt!
![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
Adam Graham
06-09-2015 06:04 AM
