suspension alinment
suspension alinment
doing some freshing up of the front wheel wells and noticed that the wheel on the drivers side sits a little further back and sticks out of the wheel arch a little bit more than the passenger side. it's as if the whole wheel base/ gerabox needs to move 10mm towards the passenger side of the car to make the wheels sit the same, is anything adjustable to do this it's a series 2. also does ford still do the lower arms and if so anyone got the codes 4 them
Sounds like something is bent to me, possibly the lower arm mounting point on the body if its had a knock previously.
You may be able to get the alignment correct with adjustable bottom arms and if its lowered they will also correct the camber.
SMILER258
28-09-2015 09:04 AM
