what size thread on egt bung on turbo housing
it looks a bit smaller but im not certain,
i would take it out and tae it to perteks with me but i only just put the rad back in and filled it with water anti freeze and i need to remove it to get the bung out the boss as its soo tight
maybe il look on turbo dynamics website
Originally Posted by Tim
TBH waste of time putting an egt there wont read right needs to go in the exh outlets as near the head as poss if you want a true reading but yes it gives an idea does your car run over run fueling just out of interest?
Tim
Tim
You can add on a figure of say 200 degrees to get the actual EGT at the port. It's more a relative aid, you know that if you normally run 600degrees, and it starts heading towatds 800 it's time to back off
rick was correct,
it was M18x1.5
Just need to find a m18x1.5 male to 1/8 bsp female adapter now
yeah it will be more of an idea then accurate,
the vems wideband i bought is a dual gauge with egt so i may as well use it, but im not putting a hole in my tubular manifold yet after paying £375 to have it coated even if they did do a shit job
plus my manifold hasn't really got room to fit it in by the collector
it was M18x1.5
Matt Baxter
16-09-2015 08:30 PM
borboyous
22-08-2015 11:17 AM
