Ford Fiesta This forum is for discussion of all things pertaining to the Ford Fiesta Range of cars.
Water in the Boot.
Old 15-11-2023, 06:59 AM
ageevt
ageevt's Avatar
Default Water in the Boot.
Others may have had this problem. I found a couple of gallons of water around the spare tire, down in that well.
Where is it getting in, and how do I stop it?
Old 15-11-2023, 07:58 AM
XR2
XR2's Avatar
Which model?
Old 15-11-2023, 10:18 AM
haz87
haz87's Avatar
If its anything remotely older its usually rear light seals. Of course I'm going to assume you've gone to the effort of identifying whether the boot seal itself is in good shape or not given it will have been right in front of you.
If its leaking so badly that you have a small swimming pool in the boot, the entry point/area should be fairly obvious and easily traceable - just run some water over the back for 30seconds, open the boot and you'll likely spot where its coming in.
Old Today, 02:35 PM
dhutch
dhutch's Avatar
On ours it was the seal sealant up near the boot hinges.
David Potasnick
Ford Fiesta
22-08-2015 10:54 PM
Martycul
02-02-2013 06:31 PM
El Kevo
22-01-2010 08:42 AM
adamski frst
Ford Escort RS Cosworth
28
07-11-2005 10:08 PM
Clare
Escort MK 5 / MK 6
01-12-2003 09:35 PM
Quick Reply: Water in the Boot.
