water in boot!!! help :( found but need advice plz!!
Old 24-10-2005, 11:46 AM
adamski frst
adamski frst's Avatar
Location: brum/shropshire drives:- frst / escort cossie
Default water in boot!!! help :( found but need advice plz!!
ok guys went to my car yesterday and there was water in the boot it had been raining it did it the other day but thought the rain came in via the water on the boot but i noticed yesterday the water is coming from the C piller i think it is the one the rear 1/4 is welded too the water was running down it frm somewhere????
i thought it could be the seal but it perfect there looks to be no holes or anything???? i'm just really confused where its coming from anyone help??
could it be frm the roof rails??
any help appreciated
Ad
Old 24-10-2005, 12:41 PM
GAZ345
GAZ345's Avatar
IS THE WATER COMING IN OVER THE SEAL?? THE SEAL GOES HARD WITH AGE & CAN LET WATER COME IN BUT IT USUALY COMES IN AT BOTTOM OF SEAL, MOST COMMON PLACE FOR WATER TO COME IN IS WHERE THE TOP SPOILER LEG GOES THROUGH THE TAIL GATE THERE SHOULD BE A RUBBER WASHER UNDERNEATH THE TAILGATE, SOMETIMES THE WATER GET'S PAST THIS DRIPS DOWN INSIDE TAILGATE TO BOOT FLOOR VIA THE BOOT CATCH, THATS WHY COSSIE TAILGATES RUST MORE THAN STANDARD ESCORTS, ALSO THERE IS LITTLE DRAIN FLAPS BEHIND THE BUMPER, THESE ARE MADE OF VERY SOFT RUBBER & CAN LIFT UP AT HIGH SPEED IN THE RAIN & WATER CAN COME IN FROM THE TYRES, TAPE DOWN THE FRONT EDGE SO THEY CAN STILL LET WATER OUT BUT WON'T FLAP UP, IF YOUR SAYING WATER IS COMING IN FROM THE C PILLAR THE ONLY THING I CAN THINK OF IS THE DRAIN PIPE FOR THE SUNROOF RUNS DOWN INSIDE THE PILLAR, MIGHT BE SPLIT BUT I'VE NEVER HERD OF THIS HAPPENING BEFORE
Old 24-10-2005, 01:05 PM
Glenn5
Glenn5's Avatar
also double check at the top corners of boot shut theres 2 circular stickers colour coded that cover bolt holes for the roof rack sometimes these lift off or split
Old 24-10-2005, 01:33 PM
adamski frst
i saw the sticker was gonna cover that see if it was that leaking but there was loads of water the seal is fine not stiff so not that could be the sunroof i'm going to check that this week the pipe may have come off or something??
Old 24-10-2005, 02:50 PM
Damo V
Damo V's Avatar
My gues would be rear light seals
Old 24-10-2005, 04:03 PM
THE RADMAN
THE RADMAN's Avatar
make sure the sunroof drain pipes go into the top of the "drain/ventilation flaps" each side of the boot and havent been pulled out,if not then like damo says
Old 24-10-2005, 04:08 PM
adamski frst
ok it doesn't seem to be coming in throught the lights, sun sunroof was bone dry when i opened it just, yet the boot was wet again!!! the c pillar was dripping again so i'm well confused!!!
alomst as if theres a hole where its falling into but there are no holes!!!
Old 24-10-2005, 04:16 PM
Tandy
Tandy's Avatar
just a thought. drop the rear seats down so you can see in the back and get a mate to pour bucket of water slowly over the tailgate just to check it's getting in around the bottom of the upper rear spoiler support. basic i know but it's worth a shot
Old 24-10-2005, 05:18 PM
adamski frst
its hard to explain really the water is running down the c pillar behind the rear 1/4 and is dripping onto the rear turret cover so its difficult to see where its coming from!!??
Old 24-10-2005, 07:18 PM
chRiS & dawn
chRiS & dawn's Avatar
Had a leak on mine and tried everything suggested above as seal looked fine. Still leaked so bought new seal anyway and it cured it.
When comparing new seal to old the old one had flattened and wasn't sealing properly. Not obvious until you put them side by side.
New seal about Ł30 but had to order it. Bought new door seals as well and you wouldn't believe the difference to the old ones.
Hope u fix it.
Chris
Old 24-10-2005, 08:08 PM
GAZ345
GAZ345's Avatar
[quote="adamski frst"]its hard to explain really the water is running down the c pillar behind the rear 1/4 and is dripping onto the rear turret cover so its difficult to see where its coming from!!?? [/quot
have you checked it's not coming in through your side window seal
Old 24-10-2005, 09:31 PM
adamski frst
yes thanks lads i checked the rear window seal its fine as i said its behind the rear 1/4 panel its running along the c pillar could it be frm the roof rails???? really depressing me we all know what water does especially in places you cant reach to treat
Old 24-10-2005, 10:12 PM
THE RADMAN
THE RADMAN's Avatar
which side? have you checked the rear window squirter pipe? that runs along n/s,it hasnt come off the nozzle or cracked where it goes through the boot grommet?
Old 24-10-2005, 10:28 PM
adamski frst
its the driver side and the grommet is fine it could be frm the patch over the hole, the ones that is either side but the patch does not feel broken when i checked it maybe aswell that i put some tape over that just encase?? eliminate that it cant be the rear boot seal as its too much water to be coming through that it soaked a small rag i put @ the bottom of the C pillar earlier on the inside of the boot
Old 26-10-2005, 09:41 PM
adamski frst
ok been out sealed the holes @ the top that have tabs on them and it rained again and the water is still running down the c pillar
does anyone know where the sunroof pipes go?? as i cant understand where this water is coming frm its not the boot seal i eliminated that
its only doing this on the driver side tho
damn cars
Old 26-10-2005, 10:09 PM
Simon Day
Simon Day's Avatar
have you tried the bucket of water trick yet?
Old 26-10-2005, 10:10 PM
cozzymatt
cozzymatt's Avatar
strip the boot area out, sit in there, get ya mate to spray with a hosepipe and you sit in the boot to see where it is coming from!!! done this loads of times at work... it never fails
Old 26-10-2005, 10:11 PM
Simon Day
Simon Day's Avatar
sounds like a fool proof plan!
Old 26-10-2005, 10:40 PM
cozzymatt
cozzymatt's Avatar
oh yes
Old 27-10-2005, 11:04 AM
Damo V
Damo V's Avatar
try opening the sunroof and jacking the front of the car up then pouriong a pint of water in the "tray", see if it runs out in the car
Old 27-10-2005, 10:55 PM
adamski frst
found is on the driver roof rail know at the back....
ok so heres my next problem mine are bonded on solid!!!!! presume thats not std how are peoples usually fastened???? need to get it off to deal with the problem ....
looks crap @ the mo but i stuck some tape on the whole rail there for now rather have tape than water
thanks for the advice tho guys i had to go through a day of testing and taking the roof lining out
Old 28-10-2005, 09:00 AM
Damo V
Damo V's Avatar
Never had them out, you sure they are bonded in and not secured in from inside?
Old 28-10-2005, 09:14 AM
adamski frst
unfortunatly there seriously bonded on can see it blatently massive blobs under it
Old 28-10-2005, 09:23 AM
Damo V
Damo V's Avatar
That may e the problem then... Not meant to be like that are they??
Old 28-10-2005, 01:41 PM
adamski frst
thats my question whats yours like???
Old 28-10-2005, 03:13 PM
Damo V
Damo V's Avatar
Dont realy take much notice but not noticed a load of bonding in there....
Old 29-10-2005, 06:09 PM
esko mk1
esko mk1's Avatar
Hi!The roof rails are bonded with body sealant from the factory.I had the same problem on mine,water came via c-pillar in the boot.The roof rail is easy to remove.Just lever the rail carefully with some wooden stick and cut the sealant with snap off blade.Then scrape off all the old sealant.Clean with thinner.Apply new sealant,and the rail while its wet.I used SIKA 11FC sealant on mine(I don´t know if thats known there?here its quite common.)Anyway its urethane sealant,and quite flexible.Hope that helps!
Old 29-10-2005, 06:30 PM
THE RADMAN
THE RADMAN's Avatar
lets hope it hasnt been leaking to long and that theres nothing nasty lurking under the rail when you remove it
Old 07-11-2005, 10:08 PM
adamski frst
jusr read this post after a few days away and thanks for the info esko mk1 yes it is the rail haven't got round to fixing it yet but i shall be in v near future there is tape on the rail for now and has stopped the leak...
looks pants but rather that than water thanks again and rememeber everyone to check yours if you get the same problem!!!
gcfcos
88
15-09-2015 03:48 PM
chris m1
07-09-2015 08:02 PM
Adam Graham
06-09-2015 06:04 AM
hopper350
04-09-2015 12:53 AM
Quick Reply: water in boot!!! help :( found but need advice plz!!
