whats needed for rear disc converson?
not sure if theres a post somwhere already about how to do this but does anyone know what ya need? cheers
Hiya mate,
I just bought mine, and you need, cossie callipers and discs, braided lines, pads, mounting brackets and all the bolts, plus a rs 2000 handbrake cable.
Neil
Neil
Originally Posted by Christian and Beccy
Don't bother IMO.
Drums are best for a road-going RST.![Top](https://passionford.com/forum/images/smilies/smile011.gif)
#1 in Spelling Club
No. The RST only weighs around 1000kg, Discs on the rear really aren't needed. It will be over-braked and this will need taming down with a Bias-valve, which can't be easily fitted due to the way the RST is piped.
My 350bhp nigh-on 170mph RST has drums on the rear.
My 350bhp nigh-on 170mph RST has drums on the rear.![Top](https://passionford.com/forum/images/smilies/smile011.gif)
#1 in Spelling Club
Yes that's true. I'm not suggesting that everyone should take their rear discs off and refit drums, but I do know people who are having issue's with rear discs. My drums have required little maintenance over the 8 years that I have owned my car and they perform superbly on the road/runway/track.
hmm i was going to do t-piece into valve then out of valve run single pipe till i get to the back then t-piece again off to discs? you dont think this is a good idea bud?
like christian said to get the best out of a rear disc conversion the whole braking system would have to be redesigned, i use to run 300mm discs form and rear, braking hard makes the back very Twitchy karl bromley at zoo motorsport made a new braking system for me Incorporating a brake biased valve two master cylinders Rerouted brake pipes etc...
but the best braking system i had was wilwood four pots and 300mm discs with standard rear brakes....
Don't mention ze Vor
I'd never even think about removing the drums. I really enjoy the strong handbrake. Very easy to do swing the back end around and do a U-Turn.
Wouldn't be the same with discs... Maybe if you use a hydraulic handbrake...
james kiely
28-08-2015 08:58 PM
track.focus'd
12-08-2015 05:53 PM
Graceland
31-07-2015 10:34 AM
