Just started my first EFI conversion job!
Not running yet though.
Got everything temporarily wired in,
Fuel pump ran, had power to my ecu, edis, injectors and coil.
Used a noid light, got no pulse at my injectors or coil pack
Can only be crank sensor, edis or pcm.
Gonna have to borrow a scope from work.
All in all, not as bad as I thought (so far).
Fingers crossed.
Fingers crossed.
Cheers folks,
All wires connected, was easier than I thought.
The only prob now is the loom we're fitting is so old and crappy, would have been better to make one from scratch
All been back probed and pin holes on the insulation and everything. Had to solder new connectors on to most of it!
Couldn't get a ckp signal with a scope, but resistance seemed quite good (about 0.08 ohms, or something) put new wires on to it and then got a great signal. Weird,
Having similar probs with the pip and saw lines too now. Very fustrating.
May be in contact with you at some point safechav, as you seem to be the daddy at this business,
Not getting to look at it again till tuesday though, fingers crossed.
