turbo spins up late, about 4200rpm?
01-06-2007, 06:32 PM
any ideas why
01-06-2007, 06:46 PM
01-06-2007, 06:47 PM
but the dump valves loud as
01-06-2007, 07:06 PM
Ok then
01-06-2007, 07:46 PM
my stupid mistake
ive just done a headgasket on the car and recent new turbo pistons rings etc so i wasnt taking it to very high revs
sooo the car does come on boost but very late about 4250rpm my old turbo started spinning up at about 2500rpm whys this, there both the same type and running same 10psi
01-06-2007, 07:50 PM
focus rs 1672
you got the hose on the actuator/compressor or the hoses on the amal valve correctly
01-06-2007, 08:23 PM
Ok then
Quote:
Originally Posted by fast_ford_uk
my stupid mistake
4250
01-06-2007, 08:32 PM
yep 4250 roughly
am not running amal valve, just checked all hoses fine
01-06-2007, 10:20 PM
zorst loose?
leak on the inlet manifold?
um, hmmm, not sure after that,
did you definatly have an rs turbo head reffited?
and is the cam timming correct>
01-06-2007, 10:24 PM
cheak your actuator, had the same problem boost was kicking in very late.
01-06-2007, 10:54 PM
#1 in Spelling Club
Actuator adjustment. If the rod is too long it will hold wastegate open.
02-06-2007, 08:58 AM
Quote:
02-06-2007, 11:29 AM
i thought that may be the problem just havent yet adjusted it. cheers guys
Chas
21-09-2015 08:57 PM
Matt Baxter
16-09-2015 08:30 PM
gabbo
28-08-2015 03:56 PM
jimmy oldskool
Ford Focus (All Models)
04-08-2015 07:06 AM
muz
01-08-2015 06:48 AM
