PDA
View Full Version : Ford Escort RS Turbo
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 [70] 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107
  1. GEARBOX
  2. Cheapest possible Zetec Turbo build?
  3. question for rst
  4. Changing Clutch Pedal
  5. how mad is this
  6. filler neck rotten
  7. anybody know how many series 1s there are left on the road?
  8. how hard is it 2 change driveshaft on a rst cab
  9. ignition timing
  10. Cossie brake upgrades
  11. where the carbon mk3 bonnet post go
  12. frst radiator vs erst radiator
  13. Loud noise on boost
  14. fuel pump
  15. FAO T28 RST
  16. 0-60
  17. mounting cps on cam pulley?
  18. fao christian *Cheers fella*
  19. adjusting actuator rod...
  20. Is it possible to fit a sunroof & power steering..
  21. Gearbox noises.
  22. Had a misfire.. is this why? *pic*
  23. EFI loom question........
  24. can anyone help me source a prt?
  25. 1.6 16V 94 gearbox--will fit rst?
  26. Overheating after Intercooler fit. Few questions!!
  27. some1 please confirm the ib5 is same fitment as bc box
  28. EFI Inlet Manifold
  29. Which oil to use..
  30. Doubts when putting a radidador of oil
  31. how much would a genuine 40k erst engine be worth
  32. Engines and Turbos?
  33. New turbo, overboosting like mad
  34. intercooler fans
  35. rs turbos in max power
  36. Trigger wheel question.
  37. quick rack
  38. What Clutch?
  39. i
  40. chrome bumper inserts
  41. abs on mot
  42. management
  43. rebuild
  44. power steering
  45. spark plugs
  46. engine rattles
  47. mk4 running 4x4 cosworth
  48. fitting cvh head how hard job?
  49. Brake Question ????
  50. cold start valve
  51. powder coating/metal finishers in essex...
  52. MFi to EFi.
  53. cvh info
  54. rst gearbox
  55. my new rs
  56. cheapeast efi trigger wheel option
  57. intercoolers?
  58. Standard escort Fuel Pump
  59. Stage 3 Head
  60. s2 turbo on a s1
  61. Foot Wells
  62. Anyone with a good knowlegde of RS CVH engines
  63. zvh torque table request
  64. adjusting rear tie bar on mk3 escort
  65. efi boost
  66. escort s2 runs but stops after a few seconds
  67. Help needed
  68. mfi
  69. S1 front mounted intercooler info needed.........
  70. Fleabay
  71. Bleed valves
  72. Bailey oil breather kit
  73. standard escort rs turbo piston/bore size???????????????help
  74. My Ford Escort Rst s2
  75. last couple of bits to finish - opinions please
  76. Engine Choices...
  77. Alternator bracket
  78. what boost
  79. CO of 0.31% ERST S2
  80. widening erst recaros
  81. carpet mats
  82. RS Logo Mudflaps for series 1
  83. diesel alternator on a rs turbo?
  84. Standard Clutch
  85. WHAT BOOST CAN I RUN ON MY ENGINE?
  86. Boost for RST
  87. can anybody help shed some more light on my problem
  88. zvh & xr3i head?
  89. lowcomp/ignition timing
  90. handbrake light
  91. harsh cabriolet, what suspention?
  92. Few Problems or Not??
  93. s1 steering rack?
  94. RR tuning/setting up
  95. AP clutch
  96. WILL S2 GRS I/C EVO5 FIT S1
  97. Auto specialists Front mount ic
  98. Steel rods in 2.1 zvh
  99. CO 2 adjuster thing on metering head?(now with pic)
  100. Engine bay stickers, calling concours S2 owners.
  101. How much is it worth?
  102. What we need for build a +/- 200bhp RST?
  103. how 2 change boot lock??
  104. electronic boost controllers
  105. Best place for recon/exchange Turbo?
  106. oil temp
  107. Series 1 rs turbo interior wanted
  108. ABS Warning light & MOT
  109. boost problem??
  110. Series 2 brake Conversions
  111. strugglin 2 get these wheels 2 fit. S2.
  112. s1 gearbox
  113. HELP !!!!! Starting problems.....
  114. bleeding procedure for s2 with abs/abs removal
  115. S1 Advise / Help
  116. Weird handling
  117. All Escort Headbolts the same?
  118. locking wheel nut issue!!!
  119. series 1 Alloys
  120. 1mm CVH Overbore. Who runs this? Comments Please.
  121. Finding a chip?
  122. Water In Front Foot Well's
  123. 200 break
  124. Rs turbo elbow, whats the power limit?
  125. Variable intermittent wiper
  126. fuel cell - need some help
  127. any info on T04E T3/T4 turbo
  128. how much boost?
  129. Group A Rally car
  130. Gearbox rebuild price???
  131. METERING HEAD FLOODED WITH FUEL, COMMON FAULT?
  132. 220BHP...... What clutch?
  133. won't start dies after a few seconds
  134. starting problems in my s2
  135. -60mm series 1
  136. Hmmmm needs another spoiler I reckon.....
  137. RST Tuning - South Wales
  138. opinions please!!!
  139. waterpump
  140. Ajusted the mixture.....now wont start!!!
  141. Uprated Speakers
  142. picture of car
  143. car donīt whant to start.
  144. Torque wrench setting zvh??
  145. s2 side skirts
  146. wat difrence will me car make with hybrid turbo
  147. wheels rubing on brake lines help
  148. remote start on alarm on s2
  149. Is this a sign of Headgasket Failure?
  150. metering head issue...
  151. grs intercooler
  152. GEARBOX!
  153. Powerchip
  154. Couple of questions about converting to efi...
  155. core plugs & exhaust gasket
  156. fuel line banjo connections. WONT START, HELP!!!!
  157. rear tie bar bushes
  158. found these in the shed today
  159. K reg series 2
  160. Clutch ratchet
  161. whats everyones thoughts on the CTS stage 1 box
  162. Needed.... Badly!
  163. orange side repeaters
  164. where can i get hoses?
  165. What tyres?
  166. exhaust mainfold gasket
  167. ST170 Head on zetec turbo?!?
  168. Ford Headbolts or Patent!!
  169. little bit of rubber
  170. decompression plates!!!
  171. Sunroof Tray
  172. car wont turn on
  173. bias valve
  174. Best place / price for forged pistons ?
  175. boost
  176. look what i have just got:)
  177. spoiler
  178. new rs turbo wheels
  179. Lower track arms S1 RST
  180. is it possible to
  181. T3 Turbo (ebay)
  182. zvh /zetec turbo suppliers
  183. Spark plugs-is this ok collor?
  184. building a 2.1 zvh advice please
  185. HELP Sump ??????
  186. Big valve heads
  187. Samco hose??
  188. altenator
  189. Fuel trip computer, does everyone else's work ??
  190. EFi Cam fitment.
  191. RS Shell...How Much?
  192. cable snapped
  193. S2 colour options
  194. Series 2 Buying guide
  195. Group A coils
  196. Efi problem
  197. Another efi rev counter question
  198. Sunroof
  199. removing throttle bracket
  200. Just changed the foam in my seat
  201. bonnet pins
  202. 19k miles escort on auto trader
  203. rear tie bar
  204. rev counter not working
  205. wat u all think of this
  206. electrical problem
  207. Front grill and now Rear End update
  208. flamer kit
  209. Buying a S2
  210. cossie 4pots on an rst?
  211. Brake caliper
  212. chasis rail welding HELP!!!!!
  213. How low on a Series 2 ???
  214. Rare or not?
  215. Rear drums
  216. dimensions of cvh rods?
  217. i ave a leek, help!
  218. Motorcraft battery
  219. What plugs ?
  220. smoaked front indicators
  221. -31 actuator
  222. no power and hesistating *fixed*
  223. What next??
  224. Series 1... worth a look/buying??
  225. S2 Windscreen
  226. Brake tips?
  227. low idle
  228. Help! I need.........
  229. Parts required to convert onion to turbo?
  230. head gasket
  231. Cambelt snapping on CVH
  232. Can I remove air aux?
  233. bleed radiator Series 2
  234. Swirl pot
  235. Look at this...
  236. Problem with inlet mainfold pressure
  237. WANTED!!!! standard actuator
  238. Newbie RST Owner...
  239. 2 problems PLEASE HELP
  240. where can i get...
  241. Strut Brace
  242. gearbox reccomendations, any info?
  243. rear brake back plates?
  244. findin it hard to get gears
  245. can you alter the amount of time or fuel the pump primes for
  246. s1 decals/stripes
  247. ADVICE PLEASE !!!!!!!
  248. fiesta turbo block ?
  249. WONT START!!
  250. compression ratio ?
