bleeding procedure for s2 with abs/abs removal
wot is the correct procedure for doing the above ..as i've heard it can be a right cunt to get a pedal...
also wot is involved converting the car to remove abs?
To remove ABS, modulators need to be removed, new pipe work to link out and ideally also remove rear load valves while your at it. I`ve read on hear its easiest to get the complete pipe work from a base model mk4 escort. Master Cylinder/resevoir should also be changed due to ABS outlets.
Basic but do a search for more detail.
