If you use a ST170 head you have to decide if you are going to run the VVT or machine up a blank for the VVT pully.
You have a chalange to find an inlet manifold with big enugth port to match the massive ports on the ST head.
S.
nah i wouldn't have thought so st170 is n/a focus rs is turboed
but the svt/st170 has forge rods/pistons that are made by mohle, focus rs does to, the difference between the two is mostly the head. Focus rs uses a 48cc combustion chamber and the svt/st170 uses a 40 or 42cc chamber. Sounds to me as the short blocks are the same and the heads are different.
is there anyway I can get pics of everything that you have ? I'm creating a database of pics and comparisions of all the different blocks and heads for the zetec.
send pics to inis@kctuners.com , I'll link you once I have the database/comparisions up.
you will strugle to fit the ST head to a silvertop block as the newer blacktop and ST's positions the cam belt in the middle of the block and it will foul the waterpump housing.
You can get round this by fitting an electric pump though
Like so, my friend will be fitting the ST170 head at a later date so he's planning ahead
I have both engines and plan to build a blacktop head with st170 block, I also already have a cast blacktop turbo exhaust manifold with t3 flange and inlet manifold both rwd set up, I'll be getting a decomp plate, gaskets arp bolts and studs butI was just wondering if there is any else that I can use from the two engines just to keep my build a bit cheaper, I've read somewhere that I can use my blacktop fuel rail with vxr injectors, was wondering if there's anything clever I can do with the water rail pump etc and the engine is going in a mk2 escort tia
The idea with a Bt top end on an St bottom end is the 1.8mm gasket gives Cr of 9:1 ( good response but will take modest boost ) if you swap the gasket for a decomp plate and two head gaskets your going to have a very low Cr. ( laggy but still with out the ability to handle big boost ).
I personally wouldn’t go to the expense of Arp stud and nut kits on a decomposing build. I would spend a few quid more on Rs pistons and forged rods at least
Mk1 Focus Rs injectors are are 440cc and could be had new for not a lot.
Blacktop fuel rail works fine. And are designed for the above injectors.
There are several firms making water rails and sumps ect.
My Rwd hybrid turbo. But I am already building a more capable engine.
I can't offer experience with a completed engine as I'm still working (slowly) on my ST170-turbo-with-a-blacktop-head build also. I have gone with the ARP bolts, I couldn't find the 1.8mm gaskets so found a 2.0mm Comet gasket which I had to buy in from the US. I couldn't find any alternator brackets these days but somehow came across a company called DA Performance Engineering which does various parts for this kind of build, RWD applications as well and specific Ford models. The bracket kit I bought includes an aux-belt idler pulley
which is mounted above the waterpump which allows me to keep the pump direction correct due to the location of the alternator. For injectors I went for Deka IV 630cc.
A lot of the parts I've been buying have been more when I find a good deal as I'm in no rush to complete the build. I've been taking time trying to source good parts but at a fair price (except the clutch... bloody hell) and some unplanned stuff like a lightened Zetec flywheel just because the opportunity came up.
What I will struggle on acheiving is the downpipe for the 2WD Sierra Cossie turbo I have. Not sure how to tackle that one. Might just phone a bunch of local places for help.
Loads of places can make you a down pipe, or you could buy a .48 exhaust housing and then use a Rs turbo exhaust elbow and down pipe.
Thanks. I guessed it's probably common enough to ask around locally, just haven't got to the point of the build to do so. Also need the o2 sensor boss welded into it. Is the RS .48 exhaust elbow different to the standard one or the same? The cossie turbo I have I think from memory is also .48 and looks well fllowed but I have no practical experience with either.
A cossie exhaust housing has a 3 bolt flange to mate to the downpipe. Where as the Escort T3 .36 or .48 exhaust housing has a 5 bolt fitting which bolts to a cast elbow 90° then the Escort rs turbo downpipe connects to that with a 2 bolt fitment.
