heads
Old Jul 18, 2006 | 10:46 PM
222tomb's Avatar
222tomb
Default heads
at the min i have a 2.l black top head but have read
sum were that the st170 head will fit on and
has bigger vales as std
im asking this because i wonna build a 500bhp zetec turbo lump
so any one with any info on this will help me thanks
Old Jul 24, 2006 | 04:37 PM
sparker1983's Avatar
sparker1983
The ST170 head should fit as they are built around the same block. However the st170 head is actually quite different. You will need the ST170 ECU to run the variable intake cam. I dont know if the exhaust cams are interchangable either, but you may be as cheap to get bigger valves put into your standard head
Nov 1, 2015 06:53 PM
Dave_b
Ford Focus (All Models)
Oct 13, 2015 05:48 PM
Mc5506
Oct 5, 2015 09:57 PM
DAZZER
Sep 30, 2015 08:43 PM
