ignition timing
13-03-2007, 08:27 PM
ignition timing
can a low comp engine run with more ignition advance that a standard one?
13-03-2007, 09:01 PM
If everything else were equal apart from compression ratio being lower then the answer is YES! boost and fueling being other factors.
13-03-2007, 09:17 PM
set my timing to 12 deg and car feels flat on boost so i advanced timing to about 18 and it feels miles better smoother,thers no det and its boosting about 1 bar. ino its alot off advance but runs better
13-03-2007, 09:32 PM
Tends to be the best way of optimising power
most of the AVA tuned cars on here run lower boost with more advance.
13-03-2007, 09:56 PM
so about 18 deg advance sounds ok for low comp?
13-03-2007, 10:12 PM
i thought you could run more ignition timing on a high compression engine,
increasing the ignition timing has a detrementle effect on raising the boost, ie, youll get les increase from turning the boost up doesnt it?
13-03-2007, 10:22 PM
you will hit det sooner if the comp ratio is higher.
Only way around this is to run a higher octane fuel.
van_dogg_pavvy
03-03-2016 09:30 AM
xrmalin
13-09-2015 06:52 PM
hopper350
04-09-2015 12:53 AM
Zoggon
10-08-2015 10:39 AM
CabrioTurbo
01-08-2015 11:04 AM
