Auto specialists Front mount ic
anyone using the front mount intercooler kit from auto specialists, its in page 22 of fast ford, seem like great value £265 for the kit, cooler, x2 slimline fans, brackets, and the boost hose outlet pipes are on the same side so the original hoses will fit
just wanna know if anyone has tested this yet?
Escort Rs Turbo
I know SaqsS2turbo got one of there rad's and it blow up and when i emailed auto specialists and asked them what ACT's they see when they tested the intercooler they said they dont know they only tested it to see what bhp increase they got with it
Seems a bit poor that they wouldnt test for ACT's as thats its primary job! lol
All there other products are quality though I believe, and it is a good price.
im fitting mine tommorow, they are this price as they are an introductory price and want to get more people to buy them, one lad with an orion rst won a front mount and had it rolling roaded when set up and got a 20hp increase which i think is pritty damn good, although i am also fitting their alloy rad as well so will see what happens.
As Andy has said though, I have not had it RR'd yet and I havn't quoted any estimated bhp increase. I was running a Pace chargecooler before which was holding 14psi and it was RR'd at 180bhp.
Since fitting the intercooler the boost has dropped to 10-12psi I guess due to the volume increase in the system but with no noticable loss in power
I have played a little with a bleed valve but unfortunately even at 14psi the standard clutch can't take it and slips like a bastard which never happened with the chargecooler setup so by my reckoning there should be a pretty reasonable gain in power from the cooler.
I do plan to fit an uprated clutch in the next few months and then I will get it set up on the rollers at about 16psi hopefully and see what the out come is. The only other thing I have done since is fitted a bailey oil separater which isn't going to make any difference really.
Anyway, I'm happy with it and for the money I don't think you can go wrong really
Originally Posted by Karlos G
What sort of BHP gain can you expect from a FMI?
I'm thinking of getting one but its a lot of money if for only a few horses!
It keeps your acts down which in turn will help stop you blowing your motor up.
It needs to be rolling roaded after fitting though!!
Originally Posted by fordorionrs
Looks cool. Got a soft spot for Onions
Originally Posted by Maxxeh
would i be able to put the fans which come with the i/c on the rad?
Well this is something I was looking into. Essentially the fans which come with the intercooler are fairly chunky and going by what I have been told by fordorionrs the clearance between the cooler and the rad can be as much as about an inch as these coolers have adjustable fixing brackets. However the intercoolers fans are too big to go in this gap, so the way I was thinking was to look into those slim line fans by the likes of Kenlowe which I suspect may fit with a bit of jiggling.
Originally Posted by Oranoco
Is this the one in Performance Ford the other month in the readers cars section?
Be interesting to see what the act's are.
The custom pro alloy one that was made for Alex's car is the Bollox beat my GRS hands down hence me now selling the GRS after using it twice
sorry mate i didnt know u hadnt had it rr'ed i only quoted what i read somewhere, i just fitted mine and it seems awsome just got to get my car setup now
Originally Posted by Jano_OddKidd
Strange. Every PRO alloy one i have tested has never been as low acts as the GRS items!
As for the core design on the pro alloy, i still dont understand it?
Custom
a pro alloy custom made item is not really a fair comparison to a grs off the shelf one
graham from grs makes custom coolers also single pass which flow loads more than is off the shelf twin pass ie: no boost drop and lower acts
another thing to consider is the flow ability at high boost some coolers start to struggle after 24 psi grs as been tested 30 psi +
I have tested all available coolers on the market at the mo and have not found one as good as the GRS items.
Ask me a question!
Ok peeps from memory!
The GRS was a steady SUB-30degree driving round town during the day etc.. Thats with a 90 spec bumper and fans on the front of the cooler.
On boost with 20psi it was still below 40degree after a long time at full boost.
(On my S1 Wens night at PF i had temps of 9degree crusing home)
The AIrtec type i have not seen get below 30degree unless on the motorway. On boost the ACT rises quickly. This is due to the fins used on the core itself.
The above was tested on the same car (Cab)
I have tested Pace large front mount (Single pass)
Air tec
GRS Evo 1 all the way to Evo 5 and custom ones
Pro Alloy FRST and ERST
2x Cossie intercoolers bodged together
+ Many more that are not worth talking about.
REMEBER THAT THIS COMPONENT IS WHAT KEEPS YOUR ENGINE AT SAFE TEMPS AND PRODUCES THE RESULTS AS LONG AS EVERYTHING ELSE IS 100%.
Air tec
thats some good info jano
when u say the act's rise quickly on the airtec, are u on about putting 20/30psi through it??
just trying to get an idea of wot sorta power, boost pressure the airtec would be suitable upto
Ask me a question!
yeah most of the cars who have had the coolers fitted by me or tested after setup have been running 14psi plus.
When i say ACT rise quickly i mean when on full boost and holding for X amount of time.
The reason is that the air inside the cooler can not be cooled down as fast as it comes out of the turbo. Thus casuing higher ACT than other coolers.
Air tec
Air tec
Ask me a question!
Ok last night @ 10:30pm driving to lakeside on a 50mph road the ACT was 17degree. When i arrived at the location the ACT had dropped to 12degree. After sitting around for about 20mins with the engine running the ACT rised to 28degree, (THIS WAS MAINLY HEATSOAK!)
As soon as i started to drive within 1/4 of a mile the ACT was back down below 20degree.
On full boost 22psi the highest i see the ACT last night was 22degree after 2.3miles of high speed.
I have NEVER had any issues with Engiine coolant temps! It really gets to me when people blame their intercoolers for high temps.
If you have a decent water system there is no reason to have any issues with this. If you have a 15-20 year old rad, crusty old water pump, and never changed the water etc.. what do you expect to happen?
The GRS coolers i use have been modified to work how i want them to having different brackets and also pipework.
But ALL GRS intercoolers which are off the shelf for the FRST or ERST from EVO1 - EVO5 have been designed to fit with the smallest amount of effort from your self. They are very easy to fit and work 100% as expected.
Im no sales man for GRS i just like to use parts and components that i trust myself on my own cars.
Better stop typing now.
Would you expect the standard off the shelf component to fair much worse act and coolant temperature wise?
vdun01
Ford Fiesta
05-10-2017 08:14 AM
