how much boost?
i have just fitted a secound hand turbo. i found it was running way to much boost. so i have unsrewed the actuater rod a few turns and have brought the boost down to 7lb at full boost.
can any one advise me on what sort of boost i should be running, the engine has a piper 285t2 cam, ported head, k&n, stainless exhaust.
i also have a chipped ecu to fit when i have run engine in. what sort of boost should i be running for that and will i need a different actuator?
thanks for any help you can give?
it depends what intercooler you are running.
personally i wouldn't run more than 14psi on standard intercooler.
if you get an uprated cooler anything up to 20psi is what peolple run but its not advisable. your turbo won't last long.
get a stage(whatever your needs are) turbo from a respected turbo tuner.
Dave
Dave
Mark RS
12-10-2015 06:01 AM
Russ Payne
25-09-2015 08:29 PM
