abs on mot
abs on mot
im taking my s2 for a mot and need some help
i took the belts off the abs when the brakes were moded, i have uprated saph cossie brakes all round i was wondering even though my brakes are shit hot that i would fail my mot for faulty abs and the light on the dash being on
cheers lewis
cheers lewis
Instant fail i expect mate.
A lot of places will be aware of the bulb being removed, the bulb obviously should illuminate with the handbrake light i believe to show its operational
You could try bridging the wiring so the light isnt constantly illuminated.
do you think it would help if i explain what ive done with the mod of the brakes and tell them i dont need it dont even know how much belts are for it to fix it
cheers
cheers
In a word......no.
I personally would either bin the ABS modulators completely, or make it so that the light operates as it should by bridging the wiring and claim ignorance if anything is asked.
In Norway.. u have to get every car mod(changing breaks, car shell ect ect) and all tuning... on cars made after 1996 u have to pay taxes pr bhp
but all mods (rebuilding, not tuning, yap some styling to) u have to get approve at the government car/road section. and they don´t like cars there and they have to wright it down in the pink slip.. or "vogn kort" on good norwegian
but the abl... its no down side thats its gone
but do as SafeChav says.
Escort Rs Turbo
Belts are about £5-10 have a look on ebay but as safechav says they wont pass it if they see you have removed just the belts or taken the bulb out because if you get pulled and the old bill get it checked (it's very unlikely but it happens) then the M.O.T guy will get fucked for it.
cheers for the input guys i will get it checked out and fixed for mot prob wont be on the road till may now though will get there in the end though
Put the belts back on .Get it M.O.T,D.
Then take the belts back off.
Or cable tie both belts sensors so they are both closed to simulate them being closed by the belts.Sensors only open when belt snaps putting your dash light on.
Zip tie the belt break sensors closed then they will think the belts are present and correct and the system will behave as though all was fine meaning the light will operate as normal.
Just oiking the belts off the modulators really isn't the way to convert a car from ABS to non ABS though
i agree with Oranoco that just removing the belts does nothing to the brakes except stopping the abs from working! the only way is to remove the modulator's completly and plumb the brake lines in properly!
when the MOT examiner type's in what car it is, the vosa computer will tell the tester that the car has abs and how he should check it. even if you tell him that it has been removed he could still fail it because it really should be there!!!
just remove the sensor's and tape them up, fooling the car into thinking it's working correctly
I agree that if you are removing the ABS then the modulators should really be removed, but in terms of functionality it can't make much difference, after all a mechanical system such as this would of taken into consideration the belts breaking during a journey.....you'd still need brakes if a belt snaps!
Originally Posted by T28 RST
Just get a friendly MOT tester
I try where possible to keep cars in a good state of repair, and thats evident by the fact they actually told me all the cars of mine ive taken in never have much wrong with them, and the fact they are willing to let small things slip because they know i'll sort it out anyway - if you try and play them for dumb fuckers then they will be harsh
don't know if this will help ive got the blue sheet the computer prints out for the tester it says
abs vsi applies: fitted as standard:with handbrake on,swich ignition on.ABS lamp illuminates and then goes out when handbrake is released.
If the switches are cable tied and fitted in position he shouldnt be any the wiser
safechav i dont even know the people who motd my car i only took it to this garage because they open on sundays i didnt " try & play anyone for dumb fuckers" if i knew i had a side light out i would have put a new one in before the mot one small thing & it was a fail.
