PDA
View Full Version : Ford Escort RS Turbo
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 [102] 103 104 105 106 107
  1. Ignition Timeing?
  2. I've still got a top end rattle
  3. S2 Steering Rack
  4. s2 runnin on 3.0l capri carb
  5. Escost cos rims on s2??
  6. which cage??
  7. No fuel to injectors
  8. Erst water/ heat problem- Help!
  9. Introducing me and my ride
  10. Piper exhaust
  11. modified car insurance
  12. Mk3/4 Bias pedal box....
  13. standed rst wheels and brakes
  14. Whats the best way to put an RS Bodykit on?
  15. Turbo Replacement
  16. All blue for sale
  17. Series 2 back fire
  18. irratic boost?
  19. Rear disc conversion causing offset problems
  20. S1 strutbrace on a S2
  21. Hello i need a picture of an RS logo to go on plates
  22. Overheating.........What Next!!
  23. swirl pot does it work?
  24. WOULD IT MAKE A DIFFERENCE?
  25. Well Lane Turbo Centre D/Valve
  26. Who done your rebuild?
  27. RS Turbo CVH, turbo oil return pipe
  28. Removing...Part 2
  29. Ford Overalls
  30. fuel injector pump
  31. series 1 turbo running problem??????? HELP!
  32. ZVH ENGINE
  33. Installed a new cam an still rattling
  34. How much are these worth?
  35. Escort S2 RS Turbo - Need Help!!
  36. pop, bang and flames!!!
  37. Escort S1 - Towing eye cover, Parcel Shelf, Dashboard Q's
  38. brackets 2 use 2wd cossie discs with standard calipers???
  39. Leaded or Unleaded
  40. neone got DTM Cup mirrors on their ERST?
  41. top speed
  42. rear brake shoes
  43. Finally got some nice Interior!
  44. RS Number Plates where can i get some from ?
  45. Lowering Help!!!!!!!!!!
  46. cossie calipers on a s1
  47. Brake Upgrade
  48. selecting gears?
  49. bailey dump valve any one ???
  50. Laguna splitter ?
  51. chrome strut brace from where?
  52. Will these wheels fit...?
  53. Wheels?
  54. RS Turbo Story (with a qeury)
  55. s1 colour change
  56. problem starting
  57. Idle problem when warming up
  58. Procedure for a new cam
  59. Bumpers, twin headlights, splitters etc......
  60. FANCY GOING ON THE FRONT COVER OF AUTO EXCHANGE
  61. new seats
  62. Cold starting problem !!!!!
  63. What Oil do you lad's use.....for your Box's?
  64. evil rust
  65. Gauges.
  66. Rocker Gasket!
  67. gearbox mount part number
  68. weird rev meter
  69. 90spec BUMPER?
  70. head gasket??????
  71. Zetec Pistons in ZVH
  72. S2 wont flame?? :(
  73. escort rs turbo smoking
  74. turbo timer
  75. S2 how much?
  76. anyone seen this around?
  77. Drivers side rear floor pan!
  78. speedo not workin?
  79. Rear disccs
  80. Roll cage help
  81. s2 electrical fault ignition coil
  82. petrol tanks
  83. MTX75 With LSD
  84. Rs turbo rep
  85. Buying an S2
  86. Anyone got bonnet vent spare
  87. Cam timing
  88. chatter
  89. Insurance
  90. help plz
  91. Amal Valve
  92. Position of AMAL valve please
  93. what would make a cam rattle?
  94. adjustable TCA's?
  95. Shell for sale for £50
  96. splitters on rs turbo's.....post your pics !!
  97. Fuel pump
  98. thinking of selling my series 1
  99. Oil Grades
  100. Bits For Sale Cheap
  101. RS Turbo Cooling System?
  102. HELP!!!! OIL LEAK PROBS BIG STYLE
  103. RS TURBOS IN YORKSHIRE
  104. flamer
  105. rear drums not workin
  106. How do you fit a forge dump valve to the crossover
  107. Cooling System
  108. escort rs turbo series 2 firing order
  109. Clear and red s1 rear lights
  110. if you had a white 90 spec S2 ....
  111. boost hoses
  112. Help please
  113. wanted
  114. Actuator
  115. RST Rad size
  116. Engine cutting out.
  117. Interesting boost question
  118. Setting mixture on S2 ERST
  119. Miss fire
  120. Genuine Motorcraft Clutch Question
  121. red s2 at papworth hospital???
  122. handbrake
  123. :( i wished this day would never come
  124. What plugs...
  125. CHIPPED ECU's
  126. good and bad points of owning a s1 rst
  127. wots my erst up to???????!!!!!!!!!!!!
  128. Poly bushes
  129. ZVH or Zetec Turbo?
  130. series1 opening rear quarter windows!!
  131. pic request !!
  132. Will this cooler be better for me...
  133. How did you deal with your escorts underside?
  134. Uprated ERST clutch, AP options...opinions please!
  135. How can i get my bonnet open on ERST
  136. For people who like bling bling
  137. Cam change
  138. zetec turbo
  139. Squeeking from passenger side wheel ?
  140. Zetec bottom end
  141. series 1 inlet manifold
  142. RST Track Day Suspension
  143. central locking problem
  144. has anobody
  145. escort turbos in heybridge!
  146. Eden Performance
  147. Top End misfire
  148. Top End misfire
  149. HELP!! PLEASE
  150. FUEL PUMP BRACKET
  151. CRANK STRENGTH CVH
  152. Can i run a Stage 3 Hybrid like this? >>>
  153. Escort Mk3 RS & Mk4 Rs
  154. S1 RS Turbo front tie-rod dimension required, please help!
  155. chips
  156. S1 insurance prices
  157. Steering Wheel Judder?
  158. I NEED HELP!!!!!!!!!!!!!!!!!!!!!!!!1
  159. piper cams!
  160. Zetec
  161. how much boost?
  162. s2 missfire
  163. Removing.....
  164. 90spec spoiler
  165. Rocker cover bolt
  166. engine mounts
  167. Cold start valve
  168. using xr3i bits on a s2
  169. Ecu chip!!!!!
  170. RS Turbo Problems
  171. What power can i expect?
  172. Smoke in the morning and when cold
  173. Guages
  174. Harsh Ride
  175. s1"s in huddersfield ????
  176. Oil coming from somewhere?? PICS!!!!
  177. Fantastic Mint Gold RS Turbo For Sale on ebay
  178. What pistons....
  179. RS turbo metering head problems
  180. pulsar intercooler
  181. How much to make a downpipe?
  182. Strange behaviour
  183. Cracked piston, and some other questions....
  184. Clutch pedal
  185. RS 7 spoke Pictures needed
  186. S1 measurement help needed
  187. fitment of piper 285t2 and vernier
  188. take a look
  189. It won't start
  190. TURBO PROB?
  191. .48 Ex housing
  192. chrome timing belt cover
  193. Headgasket change - Parts needed etc...
  194. uprated gearbox
  195. best cam for erst?
  196. Now the exhaust as well!!
  197. Water Injection
  198. RS 7 spoke help
  199. ARE FIESTA RS TURBO PISTONS THE SAME AS THE ESCORT ONES?
  200. What output?
  201. s1 what the fcuk ????????
  202. ST170 brake setup for RSTurbo (PICS)
  203. delocking
  204. Sub Interference
  205. Fuel Pump Pressure
  206. Master cylinder!!!
  207. Headgasket
  208. s2 rear disc conversion
  209. my mates got some bits 4sale
  210. anyone got a thermo time switch thingy
  211. ERST Boost
  212. Jam sport
  213. What do people reckon to head spacers????
  214. What do people reckon to head spacers????
  215. whats the best zorst for a s2
  216. help ! fueling
  217. ALTERNATOR PLS?
  218. my 17" wolfrace voodoos for swap..............
  219. What size disc's?
  220. thinkin bout breaking me s2!! any1 interested
  221. Question for all RST owners Re:Cylinder heads (example pics)
  222. Help! Oil pump
  223. help metering heads
  224. Dipped beam not working???
  225. Relay problems and missfiring
  226. MK5 Turbo Conversion - S2 Wiring Diagram
  227. Spacer plates for the head
  228. Compression ratio
  229. nitrous on a s2 erst ????
  230. Pic of a S1/2 Turbo cylinder head needed!
  231. rs turbo bonnet for sale
  232. Engine builders
  233. Zaust manifolds
  234. Turbo engine is high expense engine
  235. mudflaps
  236. misfiring s2
  237. What lowering springs
  238. 17's on series 1?
  239. how much.....?!
  240. s1 tinted red/grey rear lights
  241. S2 uprated fuel pump?
  242. series 2 prob
  243. Smoothed bumpers on S2 (PICS)
  244. mk4 escort qter
  245. S2 wheels?
  246. BEDFORDSHIRE RS OWNERS CLUB?
  247. not starting - fuelling
  248. Fitting a boost gauge >>>
  249. what s the best oil to use in my s2?
  250. Rear Tie Bar info needed?????
