boost hoses
boost hoses
when using the amal valve, where does the turbo and actuator hose go to, top or middle of amal valve?,
can u also put the bleed valve in line wi the actuator hose going to the amal valve?
Personaly i would run your car without the amal valve and run the hose from the compresser housing to the actuator with the bleed valve in line. If u havent got a boost gauge then get one cos u can make sure u run the right amount of boost. Mine works fine this way.
Russ Payne
25-09-2015 08:29 PM
