Who done your rebuild?
me and my cousins (Cossie power) well done a few actually lol
engine 1 (belongs to Hardeep Singh on here):
1600cvh
steel rods
MAHLE pistons
cossie 2wd intercooler
stage 3 head
stage 3 turbo
uprated oil pump
new water pump
complete gasket set
waiting to be setup by Karl (expecting about 195-200hp @ wheels)
engine 2:
1600cvh
same spec as above but with Pace cooling
Setup by Ahmed Bayjoo (around 240hp)
engine 3 (yet to be built):
my 2.1 16v zetec turbo
steel bottom end
flowed head
MAHLE pistons
kent cams
T34
SECS S8 management
etc etc etc
(hp unknown LOL)
prices best to PM Cossie power and see what he says
bassboy
1600cvh
steel rods
MAHLE pistons
stage 3 head
stage 3 turbo
uprated oil pump
new water pump
complete gasket set
engine 2:
1600cvh
steel bottom end
flowed head
MAHLE pistons
kent cams
T34
SECS S8 management
etc etc etc
(hp unknown LOL)
bassboy
Rebuilt my own engine...
1600CVH
0.5mm oversise pistons with 1mm machined off to lower compression
Lightned and balanced bottom end - flywheel, crank, pistons and rods
High pressure oil pump
Group A head gasket
Ported and polished cylinder head
Piper T2 camshaft and vernier
Samco coolant, boost and oil breather hoses
Pace charge cooler
Standard Escort T3 (for now) Cossie 4x4 soon
Group A dump valve
Scorpion exhaust
Quickshift air filter
Bayoo chip
Magnecor leads
Full chrome/detailed engine bay (Bailey, Auto Specialists and some 1-off bits)
AP clutch (balanced with bottom end)
Strengthend gearbox/diff (Bernie box)
1600CVH
Group A head gasket
Pace charge cooler
Group A dump valve
Scorpion exhaust
Bayoo chip
Magnecor leads
right been meaning to ask this! when you rebuild an engine with a high lift cam fitted too!...how do you run the cam in cus i thought you was ment to run it at 2k for 20mins straight away!......didnt think that would be good for a BRAND new engine to be run at that speed 20mins before its seen the light of day!
and am i the only person that cant build an engine or what?
When i rebuilt my engine i was goin to put the old cam and lifters in while i was running it in. In the end i decided not to, fitted the new cam and set the cam timeing up properly (DTI on the on the oiston to find true tdc then on an old lifter when i was setting the timeing). When i was rebuild the engine i made sure i put plenty of engine assembly lube on the crank bearings and cylinder bores and cam/lifters etc.
I started the engine and made sure i had oil pressure, then i sat at 1500rpm for 1min. Stoped the engine and checked for leaks. Next i did 5mins at 2500rpm, then checked for leaks again. Then i did 10min at 2500rpm and so on.
After thhe cam was bedded in i did 1000miles runninf the engine in at no more than 3000rpm and only coming on boost slightly towards the 1000mile mark. After 1000miles i changed the oil then gradually increased the boost.
a place that i can say deffo DONT go to is a place called southern engines in charlton south east london
complete bunch of wan*ers, fuc*ed my engine up completly and refused to take it back, had to go court int he end
word of warning guys dont go there
07-10-2015 12:56 PM
Mc5506
05-10-2015 09:57 PM
