PDA
View Full Version : Ford Escort RS Turbo
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 [57] 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107
  1. Best Mk3/4 suspension?
  2. what turbo to go for?
  3. Hissing while bleeding brakes
  4. VOODO1
  5. adjustable TCA
  6. Pedal Boxes
  7. mk4 front door cards into mk3
  8. What cps on ZVH
  9. STAGE 3 T3/T04E Turbo on a ERST
  10. front speaker sizes
  11. Intermitant wipers...........
  12. Hmmm, not to sure about this one.
  13. series 2 problem :(
  14. mef tca help needed asap
  15. Front mount intercooler-which one?
  16. pistons
  17. wires in dash
  18. oil pressure problem
  19. help needed regarding my s2
  20. brakes
  21. metering unit
  22. how do i tell if i have a lsd fitted?????
  23. what sort of power with this set up?
  24. air truppets 4 quad lights
  25. what turbo is this ??
  26. Standard cam in a stage 3 head
  27. had my car rolling roaded
  28. airbox questions.
  29. Blocking off Cold Start Injector
  30. water through fuse box
  31. water from fuse box
  32. rst ecu
  33. deflex polybushes
  34. s1 brakes
  35. compression
  36. rear brakes
  37. Improved cooling
  38. t3 turbo
  39. Vibration in reverse
  40. failed its mot
  41. series 2 switched ignition pickup
  42. Repairing a S2 Metering Head.. Possible?
  43. CPS current
  44. brakes
  45. engine bk in but wont start!!!!!!!
  46. Zetec Steel Rods and forged pistons
  47. tapping noises
  48. converting to ofab from xr3i efi
  49. headgasket sets for erst
  50. Shells
  51. mk3 boot release
  52. what tools do i need to change a metering head
  53. Does anyone know
  54. white smoke
  55. Armal Valve
  56. 90spec interior for 88spec
  57. anyone needeing a mk 3 shell ?/
  58. B&M Shifter RST Group Buy
  59. stalling
  60. is the fuel pump relay pink?
  61. Spotlamps
  62. FAO jessie_rs & Maxxeh
  63. what do you think of this?
  64. Temp. Problem
  65. zetec rod bolts
  66. quick question
  67. series 2 rs turbo bonnet wanted urgently
  68. s2 gearbox
  69. s1 lsd
  70. 18's on s1
  71. CVH rocker cover
  72. QUICK QUESTION.. About Air Flow Meter on S2
  73. Induction Cone or Standard Air Box?
  74. Crazy running engine on MFI
  75. als
  76. need new head
  77. Engine Biuld
  78. help...........
  79. s2 wont start
  80. what inlet manifold for my 2.1 zvh
  81. wanted S2 chipped ecu
  82. rs 4 spoke
  83. Yellow relay?
  84. coolant/ancillary pipe help please
  85. gotech wiring/s2 help
  86. Stage 3 Head - more advance
  87. ECU chipped?
  88. Who wants an engine? :)
  89. Wanted!!!
  90. Who do you insure your classic with?
  91. front seat wont slide forward ?
  92. boost guage
  93. Help
  94. Sandwich plate
  95. rear disc conversions
  96. fifth injector
  97. Please Help - S2 RS Turbo, Starts Then Cuts Out... BUT...
  98. converting a escort L to rs turbo
  99. cold start wont idle
  100. ACT's
  101. Fitting a aftermarket breather
  102. How much????!!!!
  103. 1.8 cvh rubber cam cover gasket
  104. fiescos dan
  105. rods and pistons
  106. cossy wheels
  107. efi engine in mfi s2
  108. New crank!
  109. Spark Plugs
  110. What colour
  111. genuine ford ht leads
  112. 1.8 zvh engine given to me
  113. back firing
  114. ERST/FRST engines...?
  115. in process of purchasing s1 rs turbo
  116. running in camshaft
  117. CVH34 question
  118. main bearings
  119. s1 boost
  120. nice and sparkly
  121. s2 rs diamond cut alloys white inserts on ebay
  122. series 2 cooling
  123. s2 gearbox oil
  124. EFI Engine to car wiring multiplug
  125. Rs turbo with escort cossie rims???
  126. ABS removal
  127. what should a newman cam have stamped on it ?
  128. Brake servo and master cyl.
  129. Top end knocking sound
  130. Fitting a Kent CVH35 camshaft...which followers?
  131. How to refurb s2 wheels?
  132. how to check if RST gearbox?
  133. 10psi
  134. Leaks!
  135. conrod caps
  136. different pistons request pics
  137. Oil question
  138. rs 7's on a s2
  139. please help me
  140. Intermittent starting problem
  141. Escos Wheels On A S2
  142. s1 anti roll bar set up
  143. Where Are All The Nice Cars Gone???
  144. Head Rests in the rear seats
  145. 2.1 ZVH Advise needed
  146. headgasket
  147. s2 gearbox oil
  148. abs removal
  149. someone fancy explaining megasquirt to me ?
  150. s2 escort clutch
  151. What turbo?
  152. series 1 anti roll bar set up
  153. Whats going on here??
  154. Speedo options
  155. Master Cylinder... Your thoughts please
  156. need a quick response
  157. misfire
  158. flat battery
  159. rst ecu chipped? knackard?
  160. 17"S
  161. xr3i efi question
  162. Fitted Gauges
  163. Oil return stub
  164. two red wires
  165. Looking to buy a series 2 RST.
  166. Head work
  167. Rs Turbo Rebuild
  168. rocker cover gasket
  169. T28 turbo & standard RST manifold
  170. zetec turbo manifold help
  171. another leak aaarrggghhh
  172. cvh EFI inlets, whats the differences?
  173. Rear disc conversion
  174. big brakes
  175. rebuilt box's
  176. Piper BP285T2
  177. Stage 3 chip and gearbox
  178. best rst clutch?
  179. 1.8 zetec short block zvh turbo ?????
  180. Engine/Gb Mounts
  181. blue smoke
  182. Anyone want to swap a stg 2 T3 for a car?
  183. hlep needed urgently regards to hoses
  184. ZVH question... again :-)
  185. no more wanted?
  186. Turbo upgrade
  187. HT leads
  188. koni front shocker
  189. cooling problems
  190. How much do engines cost?
  191. Mk3 Turbo - Oil spraying from dipstick tube
  192. s2 master cylinder
  193. billy rst
  194. fuse box removal
  195. explain play in turbo
  196. MK3 waterpump
  197. s1 and s2 rear lights
  198. non turbo block
  199. in desperate need of a cam
  200. s2 running problems any ideas
  201. engine running problems overheating!
  202. Turbo other than Garrette any good??
  203. Escort cosworth wheels
  204. my new toy...
  205. 88 spec fitment
  206. Power steering...
  207. Series one rocker cover S2
  208. ofab efi conversion
  209. Track & Drag suspension
  210. ha ha ha just licked a 310bhp skooby
  211. efi frst conversion
  212. snapped throttle cable
  213. replaced head now oil mixed with water ? ??
  214. Should i sell it?
  215. Mk4 Cosworth?
  216. 2.1 Zvh Build??
  217. Mongoose silencers
  218. anybody know this RS?
  219. What do you use?
  220. t34
  221. Where have all the pages gone ?????
  222. mtx75 help please
  223. T4 &cossie management
  224. Clutch bolts
  225. Power Steering in a Series1 ?
  226. Wheels in a 17"
  227. rs vs. type r
  228. Rear headrests
  229. S1 Arched Rs Turbo
  230. CPS to triggerwheel distance
  231. t4&cossie management
  232. high impact polycarbonate windows...
  233. drivers seat needed!
  234. st 170 turbo
  235. no indicators
  236. Fiesta ST Front Brakes
  237. Bottom end gasket troubble...
  238. Fuel Gauge
  239. car keeps cutting out
  240. Green relay
  241. Escort Cosworth Interior Change
  242. vacuum pipe id
  243. show car with pics of wheels
  244. mk6 escort to rs turbo HELP!!!
  245. Mongoose exhaust for Escort Turbo needed !!!
  246. rs turbo with Mfi XR3i Plenum
  247. My new and 1st ever rs turbo
  248. seriesone dip stick
  249. Efi Sensor
  250. Fuel tanks
