Fitting a aftermarket breather
Old 06-04-2008 | 11:16 AM
EssexMikeSi's Avatar
EssexMikeSi
Default Fitting a aftermarket breather
Does anybody have any pics/diagram of where to have hoses etc. Im just bit puzzled as theres the pipes that go to the cooler that the oil filter mount to etc but also the oil pipe that goes to the bottom of the block near there. What do i need to do?
Old 06-04-2008 | 03:52 PM
JamboRS's Avatar
JamboRS
focus rs 1672
the 2 tops outlets go to the rocker outlets,1 of the bottom outlets goes to block and the other goes to metering head or to a catch tank,sit it in place and youll see it better,do you have the fitting kit with it,and dont attach it to the oil cooler,thats water thats going thru that
Old 07-04-2008 | 06:48 AM
EssexMikeSi
thats excellent help thanks mate. i don't have a fitting kit just got a load of braided hose that im cutting to length.
If i use a catch tank, im guessing i just block off the part on the metering unit yeah? is that the part next to the outlet that a vacuum pipe goes to from the amal valve?
RUBY123
22-10-2023 12:04 PM
manuel boeckx
13
03-10-2015 02:29 PM
JoeyBoyden
18-08-2015 10:52 PM
gingerturbo
18-08-2015 07:58 PM
RsS2daz
14-08-2015 05:26 AM
Quick Reply: Fitting a aftermarket breather
