ECU chipped?
Red, Blue, white = S1 ecu with no knock sensing. you can not tel if it is chipped or not from the markings on the cover, you would have to take it apart and inspect the main chip..
cheers
Steve
cheers
Steve
"10psi. "
Is it not only the 90spec (hearts and diamonds) ECU's that allow up to 10psi?
Denbo i think even if it has a knock sensor you can just unplug it mate.
red blue white is actually a s2 ecu with no knock sensor
blue red blue is a s1 ecu
all erst ecus can run roughly 8 psi as std apart from a 90 spec one which can run 10 psi
unscrew the back of the ecu then unsrew the board from the casing then turn it over and have a look at the chip, if its a aftermarket one it should have a sticker on it saying which company fitted it if ur not sure then post up a pic of it on here
