Zetec Steel Rods and forged pistons
Bodybuilding
Location: Cannot be identified by the information given.
where can i buy these from i have seen them for around both for £500 but how long do they take to come from the usa ??
if they are the same pistons as mine je 185915 then on a zvh if i remember 8:5:1 they are meant for the black top engine but can be used in the sliver top which i am currently running.they are 85.007 mm bore.
sean
85 mm bore mate,these would work better for a cvh in my opinion,with the cvh head 55cc,thats not skimmed,would work out to be around 7.9-1....8.0-1,ive gone down another route cos these were9.01 with a zetec head and i want to go lower
Are you running a decompression plate still?
I have these Rod & Pistions a ferriday de-cat plate on a zvh lump.
Im temped to remove the plate and run 8.5.1 if correct? and lower boost but a better turbo GT28 or GT30.
Jim
why dont you just send your cvh head to ferriday and he will do the combustion chambers for you for 160 and get 8.0-1
sean
SMILER258
28-09-2015 09:04 AM
