als
als
who is running als on big bhp zvh conversions,some people say its a must if you have got t34s with miram shafts and level 8 cossie ecus,i know you need a chip to run als but what else do you need.
cheers
cheers
Not an expert on ALS but that's how I thought it worked.
Lee
On some ECU you may even require a baby board.
You need to edit modify the throttle body in the manner shown in this thread also
https://passionford.com/forum/general-car-related-discussion/232954-als-please-explain.html
What people forget to tell you is the car will often idle poorly when you have ALS.
als
thanks for the info because the reason i asked is i have just got a t35 stage 3 with miram shaft ect, and a l8 ecu with an evo chip with a closed loop , which way would you go to setting it up to try and reduce the anti lag if any.
cheers
ray
cheers
ray
if your turbo is lagging massively, I would consider getting a turbo more suited to the car and how you use it and getting the car live mapped.
als
i have got an t3 stage 3 tt hybrid on at the moment which works ok so i was just wondering if using a t35 stage 3 is it going to give more umph
all depends on the amount of boost you are running I would assume, im running a T3 with a .48 on cossie management, and would not wish to run anything else as I find it has pretty good response, minimal lag with my spec while producing reasonable power.
What sort of power are you looking for and how much boost are you going to run ?
turbo
with out going into to much detail this is some of the spec 1.9 hardenedcrank,h section rods accrilite race pistons, wire wrung block,lean burn cylinder.cossie managed, l6 ecu ,etc etc so i am looking for 300 bhp,i dont know what its bhp is at the moment till i take it to the rolling road at jam sport, thats why i was going to put the t35 on and the l8 ecu.
i hope you can see where i am coming from.
what do you reckon.
cheers.
ray
You should be able to hit that without to much problem, providing you want to run enough boost through it, I do not personally see the need for the L8 and I do not think you will see the improvements you expect to see to justify the additional money
I run a P8 on my car with coil pack, water injection, air injectors, als which to be honest is a overkill compared to the L6 which would have done everything I needed, only I wanted all the toys
Stavros
23-12-2004 07:14 PM
RickDraper
12
26-06-2004 11:50 PM
