misfire
misfire
my escort has started to misfire, only seems to happen at 60 and upwards. duno how to reali explain it but, it starts cough and splutter, i can feel it tryin to pull but i wont go.
it did it 2day on my way to work and it back fired and i lost all power!!!!
any help
cheers bret
any help
cheers bret
could be any thing mate, its just a case of elimination it maybe ignition or fuel related which side you start is down to you, if it pops then cuts out maybe a fuel fault check fuel pump voltage and see if it makes any funny noises like buzzing real loud they should not be overly loud then go on to metering head look in the air chamber under the filter make sure there is no fuel in there if all seems good check spark plugs, leads etc and the heated seat fuse if still no good give us a reply.
cant be anything,has to be something
not fuelin anyway
id say overboosting
is it chipped?
check your not leaking boost from somewhere
do u have a boot gauge?whats it showing
not fuelin anyway
id say overboosting
is it chipped?
CabrioTurbo
01-08-2015 11:04 AM
