17"S
17"S
Anyone got 17" wheels on they s2 with 17 205 40 tyres?My car has with standard ride height and rears catch the arches,is there anything i can do to stop this other than cutting and changing wheels?
I've got RS 7's on mine which are 7.5" wide with 205/40/17 tyres, no arch mods, koni's, lowered 40mm and mine doesn't rub. I've found tyre choice (cheap tyres seem worse), wheel offset and suspension make a huge difference rather than the actual size of the wheel.
I'm pretty sure my 17's are ET35 and I use Yoko Prada Spec 2's (although I've not really seen my S2 for quite some time. Never had a ny clearance problems until I had a new arch section welded in due to tin worm. Now I get some scrubbage. Nothing Andy the Anglegrinder can't sort for me though. lol
i ran fox evo 3 in a 17inch on mine 7 inch wide with a 205/40 tyre , car was dropped on a jamex kit and never rubbed once the trick was after talking to a few wheel firms was a focus offset of et40
When i got my car i had Voodoo's on the car in 17" rubbed like fuck on every corner, i changed them for my Dare V1's which are a 40mm offset.
These were fine uintil i put the rear discs on it then the rears started rubbing slightly until the tyre wore the kit and only rubbed on really bump dips on the road.
This was it fully loaded going camping
if i remember rightly if you put a rear disc conversion on it pushes them out 1-2mm dont sound much but that will be why you had a little rubbing after fitting , if your using the standard drums et40 is the best bet
Ill health and a serious lack of interest mate
Its easily repaiable but i cant be arsed with it anymore
Here is a post with all the bits
https://passionford.com/forum/ford-rs-turbo-parts-for-sale/231239-i-m-breaking-my-car.html
Davie
Davie
